20mm thread (04-early 06) front axle nut conversion
Due to many requests we have started to make a front Hex Head axle nut again to suit the 2004 - early 2006 bikes (20mm threaded axle). If you are not familiar with this, it converts your allen key front nut to a 'Yamaha style' 22mm hex nut. This means you can carry a Yamaha 22/27 spanner to take your wheels out and throw away your allen key.
http://www.mainjet.com.au/product_in...5658ed0731590e Also see the spanner & nut kit available. http://www.mainjet.com.au/product_in...roducts_id=290 We also stock the later model kit to suit late 2006 - to current years with a 22mm threaded axle. |
TKS |
I have these on my bike, great setup. good with the spanner also as it does the plug and front and rear axle.
I also grabbed th eaxle puller for the front. Cheers Mark. |
Any way I can tell which nut I need with out pulling the axle out and measuring? :D
I have an 06 with zokes forks. |
If I were you Brian, I would PM Keg, He will know what to supply you.
He is not too bad a bloke either.:D Cheers Mark |
Thanks Wence,
Check freight here: http://auspost.com.au/index.html It would be $10 or $15 for all internationally deliveries for small stuff. I think our web site tells you it is $20 automatically, but I manually charge it so I try to make it reasonable. Brian, just take the axle nut out and measure the thread. It should be about 20mm or 22mm. |
Last ride my front axle nut decided to disappear :/
Tried to order from the website and it is saying "No shipping available to the selected country". Is it true? I'd really like to use a socket instead of an allen key on my front axle. |
