2012 300 ec racing , fork bushing crossover
just wanted to share another parts crossover ,, bushings for the marzocchi 48 mm forks honda part number 51414-krn-a41 2ea. , and honda part number 51415-krn-a41 2ea. this would be for all 4 bushings for both fork legs ,, hopefully i will be replacing the bushings by next weekend and will be sure to report back with the fitment ,,, currently i have excessive play in my forks legs and am trying to tighten things up , the play seems to be coming from the bushings , ill be sure to report back with the results ..... by the way , the honda bushings cost around 20 dollars for all 4 , not bad ......
installed these bushings last weekend , they are a perfect fit ..
Thanks Smoker, that's what I wanted to hear.
What year honda did the bushes come out of all I can find is part# that ends in a31 not a41
They'll be the same bushings from any 48mm KYB fork. CRF450R 09+, or just about any Yamahahaha.
Make sure the top bushing is floating on the fork a bit. It should be able to spin around with little force. |
cheers |
