2011 ec300 clutch basket bearings
Does anyone know where i can source 2 of the open style needle bearings that support the clutch hub on the big shaft.
They are approx 33mm OD, 29 mm ID and approx 12.5 mm wide. Afriend of mine crashed on his clutch case and damaged these bearings. Thks Cactusreid ps: i'm in canada, so a canadian source would be the best,but anything you have helps! |
Gofasters will have what you need.
thks linclon!
