1997 EC 250 Forks seals
Hi guys
I have a 1997 EC 250. Tough to find manual info for it. I'm trying to figure out what size fork seals go in this bike. It has the standard forks (not inverted) 45mm marzochi. Trying to find a shop manual and the seal size so I can get them ordered! Thanks for anyone with any info!! DM 😃 |
You'd probably be saying where you are located so people from that area can point you in the right direction.
in regards to a manual there are none for the really old bike, a 2000 one will do you can download it from gasgas.es |
Take your seal out, measure the outside diameter and the height, then Google
ID x OD x L Such as 45x58x7 You might even find identification numbers on the seals if you just pop the dust seals up |
I am not sure the 2000 manual will help because I think they switched to WP43 forks for 2000.
