Stock settings for '99 EC200? HELP!
Just rebuilt the front and rear suspension to stock specs, no revalving. I found the manual for the front marzocchi forks, conventional. It says to not go farther then 2 clicks from the factory setting in either direction.
What is the stock factory settings? I don't have a manual for the ohlins rear shock. Does anyone know where to start with it?:confused: |
I'd count all the clicks and start somewhere around the middle. Start slow and dial it in with the feedback the bike gives you.
Thats what I've been doing. What to see where I am according to where gas gas thinks I should be.
The front feels a bit harsh/stiff/firm in the middle of the compression adjuster. Went out 3 clicks from centered and it is better but not as soft as I like it. At 5 clicks out, from centered, on compression it starts to get a nervous slight head shake. Also, the front wants to washout. No grip in corners front slides all over the place. I run S12s that are still very good, only about 2 hrs on them. |
