2011 EC300e part out
Bike has 270 hours on it.
Parts are sold as first come first serve basis. All prices do not include shipping. Prices not written in stone, hopefully they seem reasonable. May of forgotten a couple things. I will keep the list up and update it so you guys can see what is left. My last part out, I under estimated some of the shipping cost, larger items I will take to Fedex to get an exact quote. Sold AS-IS SOLD Engine minus e-start assembly, ran great when I parked it, needs counter shaft, may need an over haul. SOLD E-start assembly, w/wiring harness, switches, gear, covers, etc. CDI $100 SOLD Pipe OEM. Dented but repairable $75 SOLD FMF-Q. Hole wore in side from side panel rubber spacer repaired with aluminum stock/jb weld. Not pretty but it works...repair hidden by side panel. $75 SOLD Marzocchi 45mm forks (stock) $385 SOLD Ohlins 888 rear shock (stock) $225 SOLD Triple Clamps 45mm SOLD Scott's stabilizer frame bracket bolton for top mount, with Fastway 1 1/8th" topmount barclamp w/hand guard combo. $175 Front wheel with fresh bearings, typical dings and scratches. Also extra brand new in package All Balls bearing kit. $175 SOLD Rear wheel with fresh bearings, comes with disc and Supersprox 48 (worn), typical dings and scratches $175 SOLD Front Axle Have 2 rear axles $25 each SOLD All plastics/headlight SOLD OEM Radiators, both crashed but repaired by Mylers SOLD Plastic Frame Guards $10 Front Brake caliper, master cylinder/lever, hose (no banjo bolt for the master cylinder or bracket for the fork, they were sold) $130 Rear Brake Caliper & Hose (No pedal or MC) $80 SOLD Magura Master Cylinder Clutch complete assembly $165 AJP Clutch Master Cylinder (needs new seals) $60 OEM Tank with Cap (no Petcock), leaked from cap when new $50 SOLD Clarke 3.2 Gallon tank $75 SOLD Carb Keihin 36mm SOLD Subframe w/battery tray, a bit tweaked but usable $150 SOLD Frame with street legal title, new kickstand/chain roller tab welded on. $400 SOLD Swingarm, with TM chain slider SOLD BRP Chain Guide (rear) worn still has some life in it SOLD IMS Stainless Foot Pegs $75 SOLD Airbox $30 SOLD Full Linkage $100 SOLD TwinAir Air Filters (2) used $5 each SOLD OEM Bar Mounts $10 Rad/Engine hoses $10 SOLD Kickstand w/Enduro Engineering wide foot. Front brake bracket SOLD Seat, small tear at the bottom towards the tank $50 Picture of bike right before I parked it. https://scontent-sea1-1.xx.fbcdn.net...18&oe=593E9C65 |
Can I get a price on all the plastic, plus the headlight, but not the frame protectors shipped to Georgia 31602?
https://scontent-sea1-1.xx.fbcdn.net...9f&oe=594AA53Dhttps://scontent-sea1-1.xx.fbcdn.net...e0&oe=59252A7E |
Thanks - sent you a PM
I would like the headlight, if it is not sold.
Is the swing arm in good shape
I'll take the chain guide. Sent you a PM.
How about swing arm and carb 300.00 plus shipping to 80602 pay with paypal
