Swingarm linkage/bearing kits
Sorry for the ignorance upfront :confused: ...now my question. On the GoFasters site they have Swingarm Bearing and Swingarm Linkage kits. From the fiche, it appears that I need to get (2) SA bearing kits(goes in between the dogbones) and (1) linkage kit for the rest? This is assuming I want to redo all bearings in the back-end of the bike. Thx!!
Moose
Ask Mark for the Moose kit,it has every thing! I have an '06 ec300.and that has 5 bearings 4 for the SW with two cylinders for the SW shaft one bearings for the shock. Dogbones are bushings.Make sure to pack them by rollilin them while applying grease and make sure your O-rings are seated properly.Make sure your dogbones are greased and the bushings are not worn or sloppy while attached.
