Stock Ohlins 888 Clickers
Hi everyone.
Just curious as to what settings people are using with stock valving. If you could follow the format below would be great. I'll post mine after I count my rebound again. Can't remember where its at. Weight (geared up): ~85kg LSC: 19 out HSC: 1 3/4 out RBND: <to enter> out (~20) Free sag: 35mm Race sag: 115mm Spring: stock Terrain: Mixed. But mostly 2nd 3rd 4th rocks and roots. Creek beds etc. / single track. |
11' Six Days 250
210# A-vet H/S LSC= 28 out HS= 2 turns out RB= 12 out Free Sag= 27 Race Sag= 105 Stock Rear spring Terrain= mixed 1st-4th gear, rocks, roots, stream beds. Single track and grass tracks. |
I'm not sure if the Six Day's models had different valving from the std model or not, but I could not get the front forks to stroke through the last 2" of travel no matter fast or hard I hit stuff they simply would not go through that last 2". I've since had them revalved by W.E.R and they now work great as does the stock valved shock. |
I haven't played with the shock too much and am quite happy where it is. I may back it out some more just to see based on your settings. I have found my forks rarely use 100% of the travel. I haven't come right out on the clickers yet. |
Good call. I have been and know others who have been really happy with the Sachs I am running. I'm still running just soft of middle so I might back them off some more yet. I might soften up the shock some more yet too and see how it feels. Mine has been compliant but may have room for some more plushness!
How am I going to adjust the preload on a GasGas, do I have to pick out something to make it?
What tools is best to use? |
Just a quick bump.
I got pretty lazy and haven't made any changes to the shock yet, but have been kicked up the ass a few times hitting square edges (mostly roots) at a decent speed (3rd gear midrange). I believe its all in the HS comp so I'll be winding it out like MJC did to 2 turns. Just out of curiosity how much do you weigh fully geared and are you still running the stock spring? As for my forks (Sachs) I have backed the compression clickers out a few more which has plushed it up and added another 5mm of air gap to them. I now use the full travel of the fork. |
no hurting hands or arms from these forks, unlike my ktm's |
