View Single Post
Old 04-16-2009, 07:32 PM
MattR's Avatar
MattR MattR is offline
Weight of Rider = 165 lbs (naked), approx. 185 lbs with gear.
Year of bike = 2007
Type of bike = EC250
Type of Forks = Marzocchi
Type of Shocks = Sachs
Fork spring rate = 0.42 (stock)
Shock spring rate = 5.2 (stock)
Bike and Rider Sag Settings:
Front bike sag (without rider) = 35mm
Front rider sag = 50mm sitting, 58mm standing
Rear bike sag (without rider) = 49mm
Rear rider sag = 110mm sitting, 105mm standing
All Clicker settings are from fully wound clockwise...
Fork rebound clicker = 6 clicks out
Fork Compression clicker = 6 clicks out
Fork/Shock Valving (stock or revalved) = Revalved by Hall's Cycle for tight woods riding.
Shock (high speed..outer dial) setting = 6 clicks out
Shock (low speed ..inner screw) setting = 10 clicks out
Shock rebound( linkage screw) setting = 11 clicks out
Fork oil weight and brand (if known) = Spectro 5wt.
Fork oil air gap( to top of fork) = 100 mm
New or old oil (recently changed??) = New, recently changed.
Results :
Type of riding you do = Michigan singletrack, tight woods with some open whoop sections. Soil varies from sand, medium sized rocks, tree roots, and dirt/mud.
How you like your suspension to feel = Soft to soak up the rocks & roots. Need decent bottom resistance for whoop section at speed. My suspension was revalved by previous owner. I would describe it as Soft and tend to increase clicker settings to compensate.
Fast or slow rider(be honest) = I would be a fast C-class or slower B-class rider by Michigan standards.
Matt
Current: 2009 Yamaha FZ1
