You just need to remove the large nut. 1/2 impact gun is the easy way.
When you install it and torque to spec just put the engine in gear and use something like an old screwdriver handle between the rear sprocket teeth and chain to keep the wheel from spinning.
15 GASGAS EC 250
19 Sherco SE 125R
