Originally Posted by Ryan.Ager
HI guys
Took the bike for an Enduro yesterday and there were some fast field sections. After the first lap, I noticed the bike smelt bad and seemed hot. There seemed to be a lot of spooge in the silencer which was smoking for quite a while after running it.
I searched some threads on here, and checked the crank drain today. I got a small amount of coolant come out, but nothing major. I'm guessing anything in there isn't great and there is an issue. Question is what's the problem. Head gasket? cylinder o rings? I'm not overly sure.
Any help appreciated.
Thanks guys!
If you have coolant in the crank case I would think it could only be 1) head gasket (o-rings) 2) center case gasket (leaking at coolant passage between the case halves 3) base gasket (less likely, as I would think you would be leaking coolant externally as well)
