Hi i used ccm 404 wheels. it came with a ccm bracket and i used a brembo caliper and master cylinder from a ktm or husky i think. i just swap it around.
i got some spacers made for the front
the back i changed the larger wheel bearing for the gg one and added the spacer that sits in between the two bearings and it all fits
the biggets tyre you can it on the rear is a 150 or it will rub on the swing arm
