In case anyone is searching for this info., I just measured mine at 43mm x 454 mm.
I had called Cannon Racecraft and their book said 470mm long (that's not right).
I believe these GG springs are the same dimensions as the YZ 250.
FYI,
Jeff
BTW, Doc mentioned spring rates above. If you're a bit new to suspension like me, recognize that there are two units of measurement used - and a conversion calculation needs to be done.
For instance, the GG Manual states 4.2N/mm front, 52N/mm rear as Doc correctly indicates. But that is NOT Kg/mm, which is another common measurement. I purchase a 5.4Kg shock spring, but the stock 52N/mm = 5.3Kg/mm. So I didn't really increase the spring rate by much. Lesson learned!
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
