View Single Post
Old 05-15-2018, 04:10 AM
(F5) (F5) is online now
Make sure you bleed air. You'll have to check oil level, but really then spring rate and oil type.
I found them deflect on roots but after a revalve they were better. Still felt they beat me up and after a couple of years some kyb sss forks revolved fixed the problem
At your weight everything will likely suit softer springs.
Going full soft on compression seem like the thing to do but it is only opening a hole which will blow through rather than progressively opening the shims.
