Originally Posted by Ponyboy
Wanted to give an update. T
During the rebuild I put a (biggest?) .50 base gasket in for a low compression, but reliable build. Is that a mistake?
That all depends on how the head is machined. With a standard head I would think you get too big squish and improper burn of the fuel / difficult jetting. Did you measure the squish?
