Thread: Stable idle?
View Single Post
Old 11-09-2011, 04:57 PM
Neil E. Neil E. is offline
Originally Posted by webmaster View Post
To minimize pullover - you also need to go with richer pilot along with GMP suggestion to back out your idle screw.
To verify: idle screw = slide stop screw (not air screw)
I would expect that if we are trying to obtain an idle with the slide as closed as possible, the pilot jet would have to be larger and the air screw turned out more so the idle air is supplied via the air screw instead of the slide.
