Old 01-19-2019, 06:27 AM
exman exman is offline
Default EC 300 2012 idle revs remain high
When started, it keeps rpms higher than normal for idle. Than I put it in gear, and release the clutch slowly with the brake on. Rpms drop to normal and stays low (I switch to neutral). Than I open the throttle for a sec and idle remains high again. The mixture screw is one turn out. I don't know what is inside the Keihin, I bought the bike a month ago and haven't had a chance to test it due to bad weather until now. Made few circles only on a field nearby and it pulls well, but whenever switched to neutral and rewed for a sec, revs stays high.
Old 01-19-2019, 07:55 AM
john r b's Avatar
john r b john r b is offline
Default jetting
I suggest pulling the carb off, cleaning it and noting the jetting and float height
general location and elevation may help also. Take a peek at the reeds while there.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 01-19-2019, 11:48 AM
Neil E. Neil E. is offline
Check your throttle cable routing carefully. Wiggle the cable at full lock (both ways) and make sure it is free to move around. Does the throttle turn easily?If not, remove both ends and inspect for a broken cable strand.
Your jetting could be lean. As suggested find out what's in there. Another possibility is an air leak somewhere.
Old 01-21-2019, 12:40 PM
Have taken carb off: it is clean but bowl gasket is broken and I'm waiting for a replacement. Float level is ok, pilot #45, main #170, needle is NOZI (never heard) 3rd noch and throttle valve #6. Any suggestion for the altitude around 1000 feet?
Old 02-10-2019, 02:56 PM
Chesh Chesh is offline
Clean pilot jet
Old 02-10-2019, 08:35 PM
Double check and see if the rpms raise as you turn the bars lock to lock. Cable routing can cause this issues and so can handle bar risers.
Need to Mellow WOT Power at high revs stay_upright Enduro Intake/Carburetion - 2 stroke 15 09-25-2017 06:16 PM
Overheating on high load and revs only, what could it be ? poelinca Enduro Engine - 2 stroke 18 07-11-2017 05:45 AM
Really sputters at high revs now motopsycho87 Enduro Electrical & Wiring 11 11-14-2013 02:04 PM
Engine won't run at high revs motopsycho87 Enduro Engine - 2 stroke 36 08-28-2013 04:37 PM
Sputters at high revs... motopsycho87 Enduro Electrical & Wiring 9 06-21-2013 10:12 PM
