Old 09-11-2016, 12:37 AM
60ratrod 60ratrod is offline
Default 02 ec400 no spark
so with this being my introductory thread, i bought an 02 ec400 off of one of my friends for $200, since he is moving from here in washington to virginia on new orders here in a month or two and had it stop running on him. he said it was a fuel pump issue, so with some research here on this forum i found out that the relays are usually the suspect. so new battery and relay later, the fuel pump primes as it should. i proceeded to make a stator cover gasket, cause for what ever reason he decided it would be a great idea to take off the stator thinking that it had something to do with it(it didn't, but at least it looked good and not cooked), fill it back up with oil and try starting it. crank crank crank and nothing, not even a sneeze. go get some starting fluid to see if i can at least get a minor cough, crank crank crank and still nothing. pull the tank back off, pull out the plug boot, and low and behold, no spark plug. back to the store for the 3rd or 4th time today for an ngk cr8e, put it in the plug boot to check for spark, and nadda.
so i'm thinking it's a shot coil, but i would like to know some specs first. how many ohms should i read on the plug wire? how many ohms should i read at the plug wire terminal to the 12vdc constant or signal(which ever one connects to the plug wire terminal) terminal? how many ohms should i get from the 12vdc constant terminal to the signal terminal?
and last but not least, where can i find a replacement coil? or can i use one of those universal deals? or is there a preferred retrofitted coil to use?
i'm not new to bikes, infact i started riding vintage japanese bikes when i got my endorsement 2 years ago. if there is anyone here in western washington that can help, that'd be awesome. i'm in mt vernon
Old 09-12-2016, 12:28 AM
i think i found a replacement. looks like vespas and piaggio scooters used them. found this out by using the manufacturer's pn bme 02. i'll let you know how it works out
Gas gas ec400 reliability ? Niall-griffiths Enduro Other... 1 02-24-2015 04:44 PM
ec 50 boy no spark D E Enduro Electrical & Wiring 0 09-23-2014 10:29 AM
No Spark fullthrottle Enduro Electrical & Wiring 9 12-31-2013 05:14 PM
New ECU?? '03 EC400 FSE seanmccau Enduro Electrical & Wiring 0 07-09-2013 02:09 AM
EC400 Won't Start motobrox Enduro Engine 4 stroke (including EFI & Exhaust) 4 02-22-2010 06:44 AM
