Old 09-20-2015, 01:22 PM
Petrolburner Petrolburner is offline
Default 2005 EC 250 headlight wiring question
I bought the bike used, with just a plastic number plate and no headlight. I plugged in a halogen headlight and it didn't work. I thought that perhaps the other wires were for a handlebar switch and that they needed to be connected to complete the circuit. Still no success so I got out the multimeter. When the two individuals were connected I went from no volts at the headlight plug to 1 volt. What am I missing?
Trevor
007 Honda XR650R
05 Gas Gas EC 250
04 Sherco 2.9 trials bike
00 Aprilia Caponord ETV 1000
93 Kawasaki KLX 650
Old 09-20-2015, 06:14 PM
Your volt meter has to be set on "ac".
Old 09-20-2015, 06:25 PM
Oh yeah, of course. I'll try again and report back. Are those two individual plugs made for a handlebar switch? Any idea why the light wouldn't work?
Trevor
007 Honda XR650R
05 Gas Gas EC 250
93 Kawasaki KLX 650
Old 10-07-2015, 04:02 PM
RBrider's Avatar
RBrider RBrider is offline
I just got the lights working on my new to me '01 XC 200. Mine had a on/off switch for the lights mounted inside headlight housing/number plate. The switch was faulty. Replaced a broken brake light switch and cleaned up the tail light and installed two new tail light bulbs.
Lights work like new, now.
RB
Old 10-24-2015, 03:05 PM
Turned out the bulb I was testing with had one beam burned out. I just mounted an LED light bar and now I'm trying to wire in a DC reg/rectifier, but I don't have a white wire coming out of the stator. I posted more details in the DC sticky at the top.
Trevor
007 Honda XR650R
05 Gas Gas EC 250
93 Kawasaki KLX 650
Old 12-03-2015, 07:23 PM
Just to follow up, I mounted a cheap LED light bar for the 25 hour race. It worked great as a floodlight. Cheap optics prevent it from projecting the light real far, but I had two Cyclops Adventure lights on my helmet and they worked together really well. I wired the light bar straight to the factory harness, no DC rectifier or anything. No flickering or problems of any kind. The only problem is that with no battery, as soon as you lock up the rear tire and stall the engine the light goes out. It's in those moments that I realize how helpful that light bar actually is!
Trevor
007 Honda XR650R
05 Gas Gas EC 250
93 Kawasaki KLX 650
Old 12-03-2015, 07:25 PM
It even stayed clean mounted up that high
Trevor
007 Honda XR650R
05 Gas Gas EC 250
93 Kawasaki KLX 650
Old 12-04-2015, 02:51 AM
poelinca's Avatar
poelinca poelinca is offline
Looks like somebody had some fun in the mud
Glad it works now.
'14 EC300
Old 12-31-2018, 11:03 AM
Nc30joey Nc30joey is offline
I know it's an old post but can you explain to me how you wired in the light bar? I've just bought one and a loom which includes a relay and a fuse. Can't get it to work.
Old 12-31-2018, 02:52 PM
Neil E. Neil E. is offline
If your bike is the 05 mentioned in other posts, you have an AC system. The relay coil in the kit may be DC coil. Try connecting the new light between stator yellow and frame/engine ground. If it turns on when the engine runs you are done. If not find out if the light bar requires DC voltage. That will require a DC rectifier to be added to your setup.
Stator white and frame/engine ground to input of rectifier. Output of rectifier directly to your new lamp (do not ground the rectifier output).
wiring question jimjim Enduro Electrical & Wiring 7 04-27-2015 08:18 PM
UK: WTB : Speedo and Headlight wiring 'shroud / boot' - Longshot ! sevenfourate "Wanted to Buy" & "Want To Trade" 0 12-08-2013 05:27 AM
2012 - 300 Wiring question StuJohnson Enduro Electrical & Wiring 13 08-25-2013 07:21 AM
Follow up - Final Headlight Wiring Question Koko Enduro Electrical & Wiring 7 09-30-2012 07:32 PM
Headlight wiring question gasIdaho Enduro Electrical & Wiring 6 03-02-2009 07:07 PM
