Old 02-16-2017, 11:22 PM
jimmydean jimmydean is offline
Default head gasket??
hello all, i recently bought a used 2011 ec250 6 days. over the fall i put maybe 4 hours on it and found it ran a little off. i checked the bottom end and joy of joys found antifreeze... then drained and purged my radiator and found oil in it. almost a good thing hoping that narrows it down to head gasket. thus my question. i was informed that there are two sizes? not sure if thats right or not but if so can someone point me in the right direction and tell me what i need?? thanks for the help guys (ps preferably a US distributor as shipping would be cheaper and faster)
Old 02-17-2017, 05:30 AM
There shouldn't be 2 different sizes. Maybe what they meant is there are 2 o-rings that you will need and each one is a different size. Give a dealer a call and they will hook you up. I would suggest Matto Cycle or Halls Cycles.
Also GasGas is kind of know to have the water pump seal fail which will create the exact issue you described. Just something to keep in mind
Old 02-17-2017, 06:56 AM
pscook's Avatar
pscook pscook is offline
Agreed on the waterpump seal failure. Head o-ring would boil out coolant as well as consume it, but not as likely to mix the oil and water as the waterpump seal as the pump seal separates the gear box oil from the coolant and the head o-rings separate the combustion chamber from the coolant.
Phil
(New bike pending...)
Old 02-17-2017, 07:00 AM
Brian VT Brian VT is offline
...and if you're replacing the cylinder base gasket(s) you should do a squish test. Often you will be better off with a thinner gasket or none at all (just some Yamabond 4).
Old 02-17-2017, 07:59 PM
ok sounds good thanks guys. for the waterpump seal would that be all i need to get or do i need other gaskets? any links to vids maybe? sorry for all the questions just tryin to do this right.
Old 02-17-2017, 09:38 PM
You will need the right side engine cover gasket and coolant pump gasket.
I would also replace the coolant pump shaft bearings.
https://www.youtube.com/watch?v=mlMbF2f4Tt0
Old 02-24-2017, 02:59 PM
ok another question guys. i decided while i have the top end apart to throw on new cylinder rings i did some research and my 2011 should take 66.4 but i was wondering if anyone can verify? thanks again for all the help!!
Old 02-25-2017, 05:33 AM
RBrider's Avatar
RBrider RBrider is offline
The earlier models, like my '01 XC200 take the smaller o rings for the head, later models like your '11 take the larger o rings. I think the change came around '04 or '05.
RB
head gasket leak? BryanMcc Enduro Engine - 2 stroke 3 03-24-2013 10:10 AM
head gasket blown out GasgasTom Enduro Engine 4 stroke (including EFI & Exhaust) 1 11-02-2012 01:50 PM
97 blew the head gasket? Cruiser General Discussions & Announcements 11 08-08-2011 09:40 PM
Blown head gasket Jakobi Enduro Engine - 2 stroke 5 08-07-2011 09:28 PM
Radiator / head gasket blown? GavGav Enduro Engine 4 stroke (including EFI & Exhaust) 3 12-05-2008 10:35 PM
