Old 04-07-2014, 11:08 PM
Default TM 125 Engine
Did GasGas ever use a TM 125 engine in the early 125 bikes?
Old 04-07-2014, 11:17 PM
Elvis74 Elvis74 is offline
Yes they did until 2000 or so.....
Old 04-08-2014, 06:52 AM
So were the TM engines better or worse than the GasGas engines that followed?
Old 04-08-2014, 02:24 PM
Caravan Monster's Avatar
I don't know the GG 125 engine, but did own an '01 TM125. It was a strong engine in both senses: held together well and also powerful for a 125, revved out very high.
Engine manuals here scroll down to the bottom of the page for the early ones.
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 04-08-2014, 06:15 PM
GasGas's Avatar
GasGas GasGas is offline
The GG 125 motor was a good strong motor. Very durable too. Their only down fall was ring wear at the exhaust bridge. But if you change the ring often enough it was a non issue. Clutch is absolutely bullet proof with no need for after market parts. So long as you throw away the aluminum plates and replace with steels. They came stock with half aluminum and half steels in 05.
2018 EC 300
Old 04-08-2014, 07:13 PM
Thank you Both!
Old 04-24-2014, 02:10 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
The '94 through '96 125 had TM engines, I know. I didn't see any more 125s until '01. Those had the GasGas engines.
The '94 and '95 EC250 had TM engines. Paul Edmondson (sp?) won the WEC on one.
I have the parts books for those bikes, if anyone needs parts numbers.
The pistons interchange between GasGas and TM. (I used to stock Vertex TM300 pistons for my customers, because I could get them from Tucker Rocky, as a less expensive source than the (then) OEM Wiseco.
I was sure glad when they got Wossner to make pistons for them in 2004. That made them available "aftermarket" both as Wossner and Athena (also Wossner, but with the coating, as Wossner named pistons come now.)
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
300 Gas-Gas Engine jacobwhittington "Wanted to Buy" & "Want To Trade" 0 02-28-2013 02:59 PM
What engine oil are you using? juuso* Enduro Engine - 2 stroke 20 08-26-2012 11:28 AM
Engine FAQ webmaster Enduro Engine - 2 stroke 7 08-28-2006 06:39 AM
