Old 11-24-2009, 06:15 AM
GG27 GG27 is offline
Default Exhaust Spacer
I just read a post by Berkyboy who said that he had installed a 10mm spacer on a ec200 and the bike sang.
What is your opinion on putting one on an EC 250 or 300 with standard pipe? I had a 5mm spacer on my 06 YZ 250 and bike hit hard of the bottom with no loss on overrev.
EC250 2008 Skid plate, rad braces, Fork bleeders
Drz 400 Motard '03 (full spec)
Yz 250 '06, KTM exc 250 '05, exc 250 '04, exc 250 '02
WRF250 '02, KDX 220 '98, DT200R '93 all sold
Old 11-24-2009, 07:33 AM
iancp5's Avatar
iancp5 iancp5 is offline
I can't answer your question but I'm interested in how that would work in fitting. Where does the spacer go and how do you get the exhaust to fit the bike when 10mm longer?
For how it might work you could check some of the stuff online about 2 stroke pipe tuning. If it's good or not will depend on what you want from the bike.
Old 11-24-2009, 08:27 AM
2 strokes 4 life's Avatar
I made one for my IT175 back in the day. It was 10MM as well. It added much more bottom end with no loose like you said. I might just have to make another one sometime soon here for the Gasgas.
2012 Ktm 300xc
2001 Gasgas EC300
Old 11-24-2009, 08:29 AM
I agree, 10mm will be too much on the 2008 which already has issues on touching the front tire on jumps. The spacer is installed behind the two o-rings at the base of the spigot. 5mm was enough to wake up my YZ with an FMF fatty. Actually I got the info from thumpertalk on their YZ exhaust review. The main difference between the 2005 and late 2006 to present YZs is that the factory lengthened the pipe length just as it exits the cylinder, giving the YZs that increadible rush right off the bottom. The stock 06-07 exhaust is the best pipe for the YZ.
200 Exhaust Spacer noobi Enduro Engine - 2 stroke 0 03-30-2010 02:27 AM
05 Reed Spacer dozerash General Discussions & Announcements 13 02-07-2009 07:49 AM
reed spacer reeve Enduro Intake/Carburetion - 2 stroke 5 11-28-2008 09:19 AM
Flywheel Spacer GAKLX Enduro Engine - 2 stroke 0 10-12-2008 05:32 PM
Reed spacer clerky clerk Enduro Engine - 2 stroke 1 09-22-2008 03:31 AM
