Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Pictures & Videos
Old 09-23-2014, 02:41 PM
Niall-griffiths's Avatar
Niall-griffiths Niall-griffiths is offline
Default Gas gas sm250
Here is my sm250 was completely standard before I got it I have done the following
Genuine piston kit and all gaskets
full service including oil change,filler and level plugs, air filter, spark plug,coolant changed,brake and clutch fluid drained complete and a new slave cylinder piston and seals.
New black rims ajp hubs spokes Michelin pilot sport tyres
new genuine discs ebc pads front and rear
new apico pro bite footpegs
New apico gear lever
new black rear brake lever
new apico short clutch lever
acerbis hand gaurds
endurance 2 speedo
renthal grips
also new covers for master cylinders rear exhaust has new stainless rivets
Old 09-23-2014, 02:42 PM
Another one
Old 09-23-2014, 02:44 PM
And again !
Old 09-24-2014, 11:23 AM
liv2day's Avatar
liv2day liv2day is offline
Nice Niall
She looks new!
Have you done anything to the forks to make 'em better for street riding? I'd guess they'd be way too soft.
I bet that thing's a wheelie monster, just roll the throttle back and the front goes airborne
Are you going to switch back and forth between street and dirt duty, or will she stay street?
Great looking bike.
Old 09-24-2014, 06:27 PM
No mate I have done nothing to them there pretty good to be fair they have a huge amount of travel so seem to take bumps ect really well much better than friends yamaha wr mortards.
actually it doesn't wheelie on power at all unless your in first gear it puts the power down unbelivably well compared to a mates cr250 motard, i can rip the the throttle in second and it only hovers above the ground not come right up, perhaps im doing something wrong lol? current gearing 13-40 but will be going 14-40 it tops out at just over 90 with this gearing so 14-40 should give me nice cruising revs at 60mph odd.
she will only stay street as i dont have a enduro setup for her as this is the factory supermoto model. As winter is nearly fully here I'm thinking of getting a 300 cylinder(head mod,port and polish) fmf pipe and silencer along with the 2011 transformation kit just need to find out what kind of work would be involved.
with the silver rims
Old 09-25-2014, 01:41 PM
liv2day's Avatar
Show's my lack of knowledge...had no idea GG made a SM bike from the factory - figured it was built using aftermarket bits
Keep us posted if you go with the 300 cylinder; bet she'd have no problem with the front going skyward with more oomph..lol. I should have thought about the gearing before making the wheelie comment; 13/40 is much taller than what I run on my 200 (12/50) - she wheelies like a fiend...lol.
Old 09-26-2014, 07:27 PM
I will let you know I need to find out about rejetting new exhaust ect ect.yeah I think the suspension is actually set so soft when trying to wheelie the rear slowly just takes it all same with stoppies the forks are so soft they just slowly compress the whole way down lol,
Old 09-27-2014, 12:30 PM
stian stian is offline
What forks are you using?
Im using Mazorachis 45s, and with all set on max hardness, its way to soft, compared to a KTM 300 Sixdays Ive got.
Jetting, using the same carb as a 300? Friend of mine who has had a couple of 300s, said I should use 200-210 main-jet. 175-178 main is waay to low for streets.
Old 09-27-2014, 03:39 PM
There the standard forks so I'm not Sure i would guess 45mm or 50mm marzocchi I will try adjusting them tomorrow if I get time and see if it makes a difference as I haven't adjusted it yet,I thought the 250 and 300 use the same carb?? If so I should be able to just rejett 200-210 on main? What pilot and clip position? Not sure what's in mine but just done a 120 mile trip of nearly all 60mph roads and it ran perfect at all speeds.
Gas gas sm250 steering lock Niall-griffiths Enduro Chassis & Body 7 09-24-2014 06:40 PM
Sm250 road gearing Niall-griffiths Enduro Chassis & Body 10 08-20-2014 11:28 AM
Advice on sm250 please Niall-griffiths Enduro Other... 39 08-18-2014 04:34 PM
my sm250 gasser dareuk Pictures & Videos 11 03-16-2010 02:18 PM
