Old 07-18-2007, 07:21 PM
gasIdaho gasIdaho is offline
Default Float Bowl HELP!
I was taking my float bowl off to re-jet and my float came off with it as well as the pin and the other part(plunger?). This has never happened so I never paid much attention to how the assembly hooked up.
My question is how to re-attach this other part which I'm assuming regulates the gas flow into the carb. Does it just slide over the metal tab on the float assembly?
Old 07-18-2007, 07:33 PM
eff's Avatar
eff eff is offline
Yes. The loop on top of the plunger just slides onto the tab on the float.
Old 07-18-2007, 09:26 PM
RBD RBD is offline
Yes, and with the two little wire ears pointed away from the pivot pin
Ron
Old 07-18-2007, 09:30 PM
Yep. Got her up and running. Classic situation. Good tunes and distilled liquids flowing. Pull off the float bowl, parts fall off and slide down into countershaft and linkage nooks. Good times......
Lodi Cycle Bowl Marathons Rick Western United States 0 12-13-2009 06:13 PM
Float issues JoshP Enduro Intake/Carburetion - 2 stroke 16 05-24-2009 05:50 PM
Float Fix gasser Enduro Intake/Carburetion - 2 stroke 1 03-29-2009 10:32 AM
ec 250 float heights????? twibs Enduro Intake/Carburetion - 2 stroke 22 02-27-2008 01:49 AM
Float height ??? bens25au Enduro Intake/Carburetion - 2 stroke 3 08-01-2007 04:28 AM
