Old 04-22-2009, 06:16 AM
gasgasandrew gasgasandrew is offline
Default power valve rattle not chain slap
HI have read many members with 2 stroke gasgas bikes with a rattle that seems to come and go my 07 ec250 does this on open trails [ ITS NOT CHAIN SLAP] what i have fould is there seems to be a lot of clearance in the power valve and at steedy speed the center flap slapes from side to side at just the right revs may be pulse in pipe what I would like to no is this a problem or do i just leave it alone as its very hard to get it to do it it just happens now and then at these revs or can i space the outer bearings to close up this clearance as i can close it up by pushing in the left hand bearing under ther power cover any help would be great
Old 04-22-2009, 08:40 AM
FFRDave FFRDave is offline
Default No help here, but Misery does love company
I thought it was chain-slap too, and I have been told such in the past. A new chainguide and sliders and a lot of checking the chains' range of motion has pretty much taken the chain-slap theory and tossed it out the window.
You are absolutely right, it just seems to happen at times. For me, it is mostly at high RPM while hauling a$$ across a big sand dune. It just sounds like a rattle in the motor.
I have been able to reduce this noise by putting enough of a bend in the actuater arm to apply a little bit of pre-load, so that at WOT the flapper is pushed more firmly against the stop. It seems like there was enough slop in the powervalve that it could kind of flap (or vibrate) like a reed on a saxiphone. I never thought about side to side motion though.
ONCE Y0U GO GAS GAS, YOU NEVER GO BACK !!
Old 04-22-2009, 05:36 PM
2 strokes 4 life's Avatar
I only ever seem to get this slap or fluttering at low speed in the bottom end or realy lugging the bike.
2012 Ktm 300xc
2001 Gasgas EC300
Old 04-23-2009, 05:52 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
same with me
Old 04-24-2009, 04:06 AM
Dingo's Avatar
Dingo Dingo is offline
Ditto, I have that at low speed.
2009 EC300 Racing
Old 04-24-2009, 06:23 AM
rpduc rpduc is offline
Are you confident this is causing your rattle? I have this same sloppy endplay situation but I can't quite envision how it could cause a consistent rattle. There was a washer (#39 on the parts diagram from my '05) missing when I disassembled the PV. I guess that's happened more than once. I ordered the washer from GF but it came wrong. 6mm i.d. instead of required 8mm. The part # size correlation is wrong at Gofasters. Mark was going to check on it so remind him if you order one. The bike ran fine all last summer and I assume also for the P.O. so I reassembled without the washer but now you have me thinking I need to find a washer... the parts list says 8mm x 16mm x 1.5mm
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
May be so... May be not so...
My Website
Old 04-24-2009, 07:48 AM
Hi pull off the pipe and covers and rock the flap side ways and what you will get is the same noise that you get when it happens when running at the right revs .the noise is not consistent its randome right revs right load sounds like a ball bearing rattling in the camber never happens in single trails or full power only light load on open trails and is very hard to get it to do it and only last for split second and then stops until the next time revs and load are right mostly at steady speed . there seems to be to much clearence we need gasgas to put closure to this as a lot of 06 07 ec are making this noise if its not a problem ok but what damage will it do in the end
Old 04-24-2009, 08:15 AM
Skidad's Avatar
Skidad Skidad is offline
How about trying a wave washer on either side instead a regular washer?Allows side to side but with some cushioning effect and perhaps less likely to get gummed up.
97 KTM 250 EXC (sold)
2016 Trek Remedy 29er
Old 04-24-2009, 12:02 PM
You guys new to GG should just relax and ride the bike. All 2-stroke power valves rattle somewhat and at different speeds, usually at idle. The powervalve has a lot of clearance for a reason, so it can operate in a dirty environment. Any experience with military firearms? Somewhat sloppy fit by design to work in dirt and be totally reliable, same idea. The parts are all steel and ride in bearings, its a simple and reliable design. No gears, o-rings, timing, etc. It has been this way for years now and if you know of a powervalve failure please let me know. I've seen them with 6K miles, 4K miles, and my own previous bikes over 2K miles.
If your actuator plate is not touching the stop bolt head with the engine stopped, there is an adjustmet under the side cover to correct this. If its WAY off, likely you dislodged a ball in the governer by pulling on the rod as was diwcussed in another thread.
Old 04-24-2009, 08:01 PM
PEB PEB is offline
As Glen said the system has some built in slop, however all three of my bikes came to me with play in the actuator arm. An Easy fix once the side cover is off. I had the pipe off last night and to my suprise the pv would slide back and forth a couple mm. Neither of my other bikes had this play. I suspect I am missing a washer somewhere.
The noise that bugs me is the clutch whiring. When the clutch is pulled in the bike is quite. Once the clutch is released the bike makes a very noticable whirring noise. Supposedly normal but neithe r of my other bikes made that noise. I suspect the basket is not perfectly weighted. I still love the thing and am in the middle of a big round of maintinence. Reeds, Exhaust repack, pipe reseal, numerous chasis rub points mitigated etc.
FSR 450 valve check and timing chain ggg Enduro Engine 4 stroke (including EFI & Exhaust) 0 04-22-2010 01:40 AM
Cam chain Slap - FSE 400 lukemillar Enduro Engine 4 stroke (including EFI & Exhaust) 11 08-25-2009 10:57 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
Chain Slap Malcolm Enduro Chassis & Body 4 12-04-2007 05:05 AM
