Old 08-02-2018, 05:25 AM
mrfreezer mrfreezer is offline
Default EC 250 2008 footpegs
Hi guys.. I have really bent and few time welded foot pegs on my 2008 gasser. I have pair of RMZ foot pegs with mounts. I want to cut old footpegs and use those from RMZ. Do you think is it possible to cut threads to frame or it would be better to weld it? I dont know if the frame on my gasser is hollow where footpegs are welded.
Old 08-02-2018, 09:10 AM
It would be better to weld it.
There's not enough material in the frame there to thread into.
Old 08-02-2018, 12:36 PM
I agree there is not enough material and the threads will pull out and you will be very unhappy.
Old 08-03-2018, 12:09 AM
Thanks guys.. That's exactly what I was afraid of. Will weld it... I than I can use good looking billet pegs frok ebay for few bucks 😂
Old 08-03-2018, 05:57 AM
Anders Anders is online now
You can use good looking billet pegs anyway. You just buy the Yamaha type. They will fit your frame (if the frame isn't damaged, that is).
Old 08-04-2018, 04:09 AM
But I have really damaged mounts too 😪😪
Old 08-04-2018, 08:23 AM
You can use the bolt on foot peg mounts off an aluminum frame dirt bike.
Cut you mounts off and weld the mounts on.
Old 08-04-2018, 08:55 AM
I found this link on Ebay which includes a WR footpeg mount with the kickstand bracket. You use the holes and edges for welding to the GG frame.
another option is to just get the two smaller YZ mounts that do not include the kickstand bracket.
https://www.ebay.com/itm/2008-Yamaha...sid=m570.l1313
Makes me wonder if this is a good option if you want to get away from the GG switchblade.
Old 08-04-2018, 08:58 AM
Or you could weld on the later Gasgas frames' bolt-on mounts. I have bolt-on mounts on my 2015, I presume this is the same from 12 to 17.
Old 08-05-2018, 01:26 AM
I already have bolt on mounts from RMZ.. with footpegs... just need to weld them . . thanks guys
Footpegs? 95jersey Enduro Chassis & Body 4 04-15-2016 10:00 AM
S3 Footpegs bazzagas Enduro Product Reviews 2 04-27-2012 12:39 AM
footpegs davedunaway Enduro Chassis & Body 17 02-15-2011 12:29 AM
