Old 05-20-2021, 04:24 PM
GasGas's Avatar
GasGas GasGas is offline
Default Sloppy linkage bolt
Is the hole in the right frame flange made oversize for a reason, or I?m i missing a bushing?
View my video at https://josey.smugmug.com/Gasgas/i-JbMjLdQ
View my photo at https://josey.smugmug.com/Gasgas/i-FgPfM7w
2018 EC 300
Old 05-20-2021, 09:23 PM
Shouldn't be that loose.
Seeing that the hole is completely round, I think that's the wrong bolt.
Old 05-21-2021, 12:59 AM
Anders Anders is offline
I agree. Does the bolt fit well inside the linkage bushing?
Old 05-21-2021, 05:56 AM
GasGas's Avatar
Yes. It's a 12 mm bolt and the hole in the opposite frame flange is the correct size. There is also no sign at all of wear on the bolt. The frame flanges have a steel bushing welded on the inside of them that protrudes flush with the outside. I'm thinking an incorrect sized bushing got welded into the frame flange or the hole is supposed to be a little over size for the bolt to be able to clear the outer frame rail by the rear brake pedal. This bolt already has a flat on one side of the head for that reason. It obviously does not move much or at all when the bolt is tightened and torqued as it would still be clamping the frame flange. it just seems odd for a 12mm bolt to have a 14mm hole, especially for some thing under that much load like a suspension component.
2018 EC 300
Old 05-21-2021, 06:09 AM
I agree. It's odd, and I don't think it was intended that way. If it was mine, I would just turn a suitable bushing to fill the void (as I have a lathe).
Old 05-21-2021, 11:27 AM
Darkside Darkside is offline
I wonder if it had a flanged bolt originally. maybe you can find a flanged washer similar to whats used for the plastics
2006 GasGas EC300 2011 KTM 300XC
Old 05-21-2021, 06:11 PM
GasGas's Avatar
The brother made me a steel flanged bushing today. The bearing/bushing in the U shaped link was the only bearing that had play, so I expect the oversize hole could have been a factor. I think I may replace this bolt for piece of mind too, just in case it suffered some fatigue from flexing.
2018 EC 300
2001 xc250 linkage removal problem. ..trapped bolt 70455 Enduro Suspension 21 09-22-2012 11:34 AM
Tight Linkage Bolt binsel Enduro Chassis & Body 5 03-18-2011 12:52 PM
Trials tires in sloppy weather??? kendunn Enduro Chassis & Body 22 12-10-2010 12:50 PM
