Old 12-06-2008, 01:25 AM
FFRDave FFRDave is offline
Default Renthal "Rivit-Link" Masterlink question
Its just a masterlink on a O-Ring 520 Renthal chain. I used the "Rivit Link".
I have a little tool that I use to press on masterlinks before I slip in the little clip. This time I got as far as pressing on the little plate, but there was no clip.
All the other pins on the chain have a little (lack of a better term) bevel in them to hold the pin into the side plates. This Masterlink side plate (that I just pressed on) does not have any bevels.
I am concerned about what will keep those pins from slipping out of the pressed on side plate. There is no clip to keep it in place.
Is there a tool I am supposed to use to MAKE BEVELS in the masterlink pins ?
I could grind a little material out of the centers and then use a punch or something to mash the pins edges over the plates, BUT THAT JUST SEEMS CRAZY & WRONG!!!
It also seems a little wrong that I just squish that little plate on and call it good.
ONCE Y0U GO GAS GAS, YOU NEVER GO BACK !!
Old 12-06-2008, 04:23 AM
bergerhag's Avatar
You need a chain riveter.
Old 12-06-2008, 10:18 AM
Well, I thought I had everything!!
I have a tool that looks very very similer to the brass colered tool on the right, but I dont have the little silver attachments. I have used this tool to press out the roller pin to remove that leftover length of chain.
The little black squares, I do not have.
I guess I have some more stuff to buy now.
www.Motrax.co.uk ??
Old 12-06-2008, 10:23 AM
bergerhag's Avatar
the two pics are just two different types, do a google search on 'chain riveter'
Old 12-06-2008, 11:50 AM
HydroDog's Avatar
HydroDog HydroDog is offline
I purchaced the one of these:http://www.motionpro.com/images/enlarged/08-0058.jpg and has worked great.
07 GG EC 300
05 KTM 250 exc
99 KTM 640 enduro
"attn." "new England Boys" RONALD BRUNDIGE General Discussions & Announcements 9 11-17-2008 08:19 PM
"B" piston in an "A" bore? Kokanee Enduro Engine - 2 stroke 6 09-04-2006 07:10 PM
Recommendation: add "Injury/Recover" and "Riding Techniques" sections MattR Suggestion Box 2 07-18-2006 09:19 PM
