Old 03-26-2019, 07:12 PM
CDBiker220 CDBiker220 is offline
Default Always 0 MPH on the enduro computer (2018 EC300)
Hey before I dig into this just thought I'd see if anyone else had this happen. My enduro computer is not registering any speed when I'm moving, just says 0mph, this obviously affects trip and overall milage. Hour meter still working. Everything looks good as far as the wire to the sensor and such. Just thought I'd ask before tearing into it.
Old 03-26-2019, 08:27 PM
GG221 GG221 is offline
There should be a little magnet on your front brake rotor. That magnet passing the sensor is how your speed and distance are calculated. Is it missing?
I hVe an XC so no speed sensor, but I think the magnet should be in this hole
File Type: jpg 6268F995-24B9-4422-8B87-8E196985DDC2.jpg (102.4 KB, 17 views)
Old 03-26-2019, 11:40 PM
GasGas's Avatar
GasGas GasGas is offline
G221 is correct, there should be a magnet in that hole with a circlip holding it in.
2018 EC 300
Old 03-27-2019, 02:32 AM
RudolfHucker's Avatar
If there is no magnet, any magnet moved quickly across the sensor in the brake caliper should register a speed.
The sensor is a mechanical reed switch and these do fail as the internals are a bit flimsy. You can test by unplugging the sensor cable at the speedo end and using a peice of wire to short across the connector. Making and breaking the connection will mimic the reed switch and you should see a reading on the speedo.
Old 03-27-2019, 12:25 PM
Saddleback51 Saddleback51 is offline
I have a 19 EC300 and it did the same thing. The problem was the plug was coming loose. Trace your sensor wire from the front wheel and follow it to where it plugs in close to the speedo and that will most likely be the problem.
Old 03-28-2019, 07:12 AM
Thanks for the tips, the magnet is present in the rotor, I had already checked for that. I will do a couple tests, double check the connection at the computer and if needed replace the sensor at the wheel. I'll follow up with what I find. Thanks.
Old 03-29-2019, 02:07 AM
masterbill masterbill is offline
Hello,
On my 2015 250 I had the same problem. Tried new battery,checked cables etc.
Pressed the reset button on back of speedo and it works !
Old 07-31-2019, 06:02 AM
Pygmygod Pygmygod is offline
Found out my 'new to me' bike wasn't recording any speed/milage on my maiden voyage on the weekend.
Had a look at it this afternoon and noticed that there's no magnet in the front disc rotor and no round hole to put a magnet.
Can only assume that the previous owner installed an aftermarket rotor, perhaps for the MX version instead of Enduro version?
If I araldyted a magnet into the gaps on my rotor, this should work shouldn't it?
Old 07-31-2019, 07:28 AM
Nocams Nocams is offline
Yep, I used sikaflex 227 on my 2010 and 2015 gassers to hold the magnet on.
The sika won?t budge under vibrations.
2011 TXT300R
2018 EC300GP
Guide to programming a 2018 EC computer AZRickD Enduro Electrical & Wiring 1 01-19-2019 11:52 AM
NZ hard enduro 2018 ec300 Bunyanator Pictures & Videos 8 10-23-2018 05:06 PM
Anyone own a Pacemaker Enduro Computer? rpduc Off Road Racer's Corner 14 07-22-2009 05:51 AM
Which Enduro Computer?? angrytim General Discussions & Announcements 13 07-17-2008 10:21 AM
Enduro computer kim Enduro Electrical & Wiring 10 07-09-2007 04:51 AM
