Old 11-05-2006, 07:41 PM
mattmax mattmax is offline
Default SAG adj MC250
Just got my 05 MC250. I expected a stiff suspension, but the rear was so tight, there was no static sag and it took pressure to get any sag.
I got set to adjust and read the "FAQ; Suspension baseline settings" and it recommended starting with 10-15mm preload. I measured my spring and then loosened it and found that it had previously only had maybe 5-6mm preload. I assume I must be running a different spring. I'll give it my best guess to try to match the forks, but I know it was way too stiff before with no hint of static sag.
Just wondering if anyone has some suggestions on sag numbers. I know my 50mm forks are quite a bit stiffer than the 45mm, so I assume I want to try to balance out the front and rear. I weigh about 190 and ride mostly woods. I like a stiff suspension, but it was at the point of being a hardtail.
Matt
Old 11-05-2006, 09:28 PM
Default estimate
I set the preload at 3-4mm and got roughly an inch of static sag and 4 3/8 inches sag with me on the bike. It's midnight, so I won't try it out just yet. Front and rear seem about the same.
Any input is welcome.
Old 11-06-2006, 07:51 AM
Eric K Eric K is offline
It sounds like you are pretty close.
I run about 30 mm static sag and 130 mm loaded sag.
Eric K
'06 GasGas EC300
'01 GasGas XC300
mc250 for the woods GP6 General Discussions & Announcements 4 03-20-2007 01:11 AM
What bike to buy DE or MC250? mattmax General Discussions & Announcements 7 10-29-2006 07:50 PM
