Old 08-18-2019, 02:49 PM
jmkjmk88 jmkjmk88 is offline
Unhappy Weak spark
Hey guys. I?ve been using this site for years to maintain and work on my 2012 300. Took the bike around the block and it just died. Thought it was getting no spark so I tried using a ktm 300 coil new plug n wire to see if that was the problem. Kicked it once and it started, idled rough and cut off after 30 seconds. Put the old coil back on and noticed it is getting spark, just extremely weak. I?ve already cleaned my grounds, checked the stator and its spotless,no rust or corrosion. checked for shorted wires and have gotten no where. I?m at a loss. Has anyone got any insight on what this could be?
Old 08-18-2019, 04:39 PM
Sounds like a stator issue.
Not producing enough voltage.
Old 08-18-2019, 04:57 PM
Tested the stator with multimeter it?s reading the right output
Old 08-18-2019, 07:41 PM
I'd vote stator too. multimeter wont pick up wires that almost touch but do when they are warm. Mine failed in similar fashion.
Old 08-18-2019, 10:30 PM
You need a peak voltage adapter to measure its output well enough to say if it is ok. It should be able to pump out at least 100 volts and the source coil and about 5-7 volts for the pick up. It very much sound like a weak stator. Also disconnect the kill switch to rule that out.
Old 08-19-2019, 02:49 AM
RBrider's Avatar
RBrider RBrider is offline
Have you replaced the wire end and boot on the spark plug wire?
RB
Old 08-19-2019, 04:45 AM
Pygmygod Pygmygod is offline
Sometimes you can unscrew the cap, trim off a bit, then screw the cap back on so it's got a nice fresh connection.
Old 08-20-2019, 02:05 PM
Thankyou for those specs. Killswitch has already been disconnected. Just ordered a peak voltage adapter should be in by tomorrow. I?m pretty bad when it comes to electrical stuff so I really appreciate the help
Old 08-20-2019, 04:20 PM
Anyone know where I can get a damn stator for this thing? Again it?s a 2012 ec300e headlight tail and signal lights? Not a single shop in New York will touch this thing
Old 08-20-2019, 06:16 PM
Neil E. Neil E. is offline
I replied to your other post, but I'll add the answer here too.
http://www.gasgasrider.org/forum/sho...ghlight=stator
Who said the plastic subframe is weak? rubber Jonny General Discussions & Announcements 3 07-16-2014 07:04 AM
Weak turnover w/ new battery INABIL Enduro Engine 4 stroke (including EFI & Exhaust) 13 11-18-2009 10:13 PM
weak spark tallboy350 Enduro Electrical & Wiring 5 11-24-2008 08:18 PM
weak spark?? Cruiser Enduro Engine - 2 stroke 11 07-01-2007 02:26 PM
