Old 11-22-2015, 05:32 PM
Default Tranny Failure
Riding back to staging area today after trail ride. Shifting from 5th to 4th gear and the bike suddenly goes into neutral. I proceed to shift down and I hear a clunk and the rear wheel locks up. Counter shaft will not move even while pulling in on clutch. Shifter shaft locked up. The kicker will not move either. Any ideas? I am going to pull the side cover when I can and take a look.
Old 11-22-2015, 06:34 PM
You will likely need to spit the cases but start by pulling off the clutch inner cover an see if anything looks odd there first.
Old 11-22-2015, 07:53 PM
RHS engine cover. Check the selector shaft assembly as first point of contact. Some have been known to break away from their weld and cause issues.
Old 11-22-2015, 09:18 PM
Thanks, just guessing at this point, but selector shaft, clutch, and idler gear seem likely possibilities...If idler gear is the culprit, will there be any way to verify with RHS cover off?
Old 11-22-2015, 11:30 PM
gg3's Avatar
gg3 gg3 is offline
oh........thought the thread was about something else
Old 11-23-2015, 03:46 AM
paulos paulos is offline
Some of them are hard to pick
2011 Gasgas EC200, 1966 BSA 350 scrambles, 1972 Montesa cota 247
Old 11-23-2015, 07:07 AM
Agreed it seems that this forums search function is somewhat limited. Unless I am not seeing an advanced option, it appears that the search function only looks for "any" of the searched words and not "all" of the searched words.
Old 11-23-2015, 08:03 AM
Moto7man Moto7man is offline
Yep, check this first.
―Comedian Lewis Black
-Unknown Sardaukar
Old 11-24-2015, 04:41 PM
gasmonkey's Avatar
Bronze Level Site Supporter
Sounds like the selector/selector drum has selected another gear without deselecting the original gear,ie is in two gears now hence lockup.
If it's done under full power the tranny implodes.I know I've seen it done.
Very expensive.
Old 11-25-2015, 12:25 PM
Drained the oil last night and there was a small piece of sheered steel stuck to the magnet. About .25" long and maybe .125" wide and deep. Not encouraging, but did not see any other material in the tranny oil or on the magnet of the drain plug. Going to pull the side cover tomorrow morning, but it seems that the cases will need to be split regardless if there is debris in the transmission.
1998 EC 250 Clutch Basket Failure Dukester Enduro Engine - 2 stroke 5 12-10-2014 08:55 AM
CDI Box Failure Mode blitz11 Enduro Electrical & Wiring 7 10-30-2013 03:27 PM
Kick Idler Gear Failure Jason S. Enduro Engine - 2 stroke 3 08-08-2011 04:19 PM
return of the son of the BMW fork failure? motogroove All Other Bikes... 1 06-29-2011 08:40 PM
Hmmmm Ring failure noobi Enduro Engine - 2 stroke 6 04-24-2010 12:22 AM
