Old 03-31-2010, 11:59 PM
noobi's Avatar
noobi noobi is offline
Default 200 powervalve rattle?
My 50 hour old 200 has started rattling rather alarmingly.
Its had a clean filter every ride, and never been drowned, and only started doing this recently.
I removed the l/h side pv cover while the engine was running and watched the pv axle rattle about with a few mm of play left and right.
Would I be correct to assume that this is the rattle I can hear?
Old 04-01-2010, 02:25 AM
noobi's Avatar
Upon closer inspection the noise may from the clutch, when the clutch is pulled the the noise stops but a rattle can still be heard. Are the bigger bikes supposed to rattle a little bit? I read that a little pv slap is expected, but this is a idle this noise
Also the bike was smoking quite badly at a ride at higher elevations, although im thinking this was a dirty filter causing a rich mix
Old 04-08-2010, 12:17 AM
911racer 911racer is offline
Did you ever figure out the problem?
I'm new to the 2-strokes so I'm no help.
2003 Cannondale E440R, 2007 KTM 990 Adventure, 2004 Husky TC450, 99 GasGas 200, 1958 Puch Allstate twingle 2 stroke, 98 ATK 260LQ, 02 RM85 for the lady.
I like motorcycles can you tell?
Old 04-08-2010, 07:25 AM
kendunn kendunn is offline
All the GG 2t's seem to rattle a bit from the power valve, including mine. If it is the power valve you should notice fluctuations in it with RPM changes. Mine would really rattle when lugged just before it came on the pipe. I think its just where its working. Made me worry pretty good, thought it was a piston skirt slapping or something. Look through the threads, lots of them on there about this.
2006 EC300, 2000 XR650R, 2003 EC250, 2001 EC200 (OK, the last two are really my sons).
pipe rattle redrider7202 General Discussions & Announcements 5 04-06-2010 07:33 AM
power valve rattle not chain slap gasgasandrew Enduro Engine - 2 stroke 47 06-11-2009 05:24 PM
Rattle in Turbine Core 2 MOREGas Enduro Engine - 2 stroke 1 06-23-2008 02:33 PM
clutch rattle? jostby Enduro Engine - 2 stroke 0 02-25-2007 05:01 PM
