Old 06-29-2014, 02:49 PM
pandomar pandomar is offline
Default Loose crank stuffer bolt and the consequences
I have had ec300 11' now about 5 month. Some bad "luck" striked me reasently. Engine suddently stopped while riding and kickstarter feel rock hard. I went home and wonderd what had happend. The magneto side plastic stuffers bolts were detached and the pistons skirt had hit the bolt and so caused the stop. Luckyly only piston and crank were damaged, there was a recipe for bigger catastrophe.. Now I Am rebuilding the engine (new piston, crank+bearings)
The new crank does not have bolts underneath as the old crank did. Should I install the bolts to the new crank?
Old 06-29-2014, 02:52 PM
and some pictures of the accident
Old 06-29-2014, 03:05 PM
If it were me, I would install the bolts and have the crank balanced. You will be very happy with a balanced crank.
At this point ,you don't know if the bolts were installed when the crank was balanced.
Use Loctite on the stuffer bolts!!
Old 06-29-2014, 08:01 PM
Rick's Avatar
Rick Rick is offline
Same thing happened to my 200......I've always been under the impression only the 200 had stuffers?..
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 06-30-2014, 12:17 AM
Those bolts seem to have quite factory look, not chopped to certain lenght as would be doe while balancing? Do some gassers have balanced cranks?
I don't really have the time to get it balanced
Old 06-30-2014, 12:29 AM
pic of the bolts
Old 07-12-2014, 04:03 AM
Loctite!!!!!
2016 RM-Z450
Old 07-12-2014, 04:04 AM
Also, 2 bolts of equal mass (weight them) will not affect the balance of the cranks.
2016 RM-Z450
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
Crank drain bolt - what is correct procedure Jaluka Enduro Engine - 2 stroke 4 09-23-2011 07:07 AM
Today's powervalve thread - loose bolt screws race motogroove Enduro Engine - 2 stroke 3 07-29-2011 04:33 PM
Loose Airscrew biggstr6 Enduro Intake/Carburetion - 2 stroke 6 07-29-2010 09:07 AM
Crank Stuffer Crossover? webmaster Enduro Engine - 2 stroke 1 11-01-2008 08:32 PM
