Old 11-05-2018, 03:53 AM
mlundstrom mlundstrom is offline
Default Good lights
Hi, I have a 2014 EC300 Racing Nordic Edition and am looking for a good alternative for getting better headlight - I have a helmet light and also would like a better alternative for the one on the bike - stock is quite useless, it gets quite dark here...
Since it's the racing edition I don't have a battery or electric starter, so something that should work with the bike as it is would be great - is it even possible, or do I have to rebuild the electrical system?
Any hints on this?
Thanks in advance,
Mattias
Old 11-05-2018, 03:58 AM
Anders Anders is online now
Any hints on this?
Thanks in advance,
Mattias
My hint would be the Endurotech lamp from Poland. I have one myself, and am very pleased with it. I think we ride under similar winter conditions, as I live in Norway. I have a 2015 EC200, kickstart only. Please see my report here:
http://www.gasgasrider.org/forum/showthread.php?t=22295
Old 11-05-2018, 07:31 AM
RudolfHucker's Avatar
There are lots of LED lamp options available. Go for as high a lumen count as possible and consider mixing a spot light and a flood light to get a good light spread. Also remember that a bright light is no good if the lens is garbage. Generally, you pay for quality but the result is worth it.
If you don't have a battery, does your bike have a power connector for a radiator fan kit? I use this to power my aftermarket lights.
I use these. I have had them for about 8 years now but they are still excellent.
https://www.adventure-spec.com/defau...tice-solo.html
No lights or horn puttyhead Enduro Electrical & Wiring 5 10-23-2014 09:39 PM
Lights went out 1RobAusdemore General Discussions & Announcements 2 05-27-2014 01:28 AM
Lights went out 1RobAusdemore Enduro Electrical & Wiring 4 05-25-2014 10:11 AM
Brake lights adv rider Enduro Electrical & Wiring 5 04-06-2014 06:58 AM
How can i turn my lights off nickp General Discussions & Announcements 2 10-28-2012 07:56 PM
