Old 06-30-2011, 03:38 PM
blanc blanc is offline
Default GasGas engine maintenance schedule...
Hi
At what hours do GasGas suggest to rebuild your engine? Presume different hours for rings and full top end .
Old 06-30-2011, 06:13 PM
Depends on how you ride, if you dust your engine, drown your bike etc etc etc..
Some people swear by doing the piston and rings as a package every 60-70hrs. Others will do a set of rings around 50hrs, and then a full piston at 100hrs. There are pleanty who do 100hrs on a set of rings.
I pulled down my 2010 at 65hrs for a fresh piston and rings. Below are pictures of what I found.
Make what you want of it.
Old 06-30-2011, 06:14 PM
I don't even bother with rings. I do a full top end between 75-100 hrs mixed riding and racing on a 250, B level. Whenever I do mine the rings are well withen spec. Piston looks good too, its just the fatigue factor to consider. I know 300s that have gone years without being opened up. Just do compression checks, keep the filter clean, good oil in both mix and trans.
Old 07-01-2011, 05:58 AM
Mines a 200. Thought i should do rings at 25 and top at 50. Will do a full top at 50 plus to be safe. What about powervalve cleaning? When should that be done ?
Old 07-02-2011, 07:32 PM
Do it all at the same time, as long as you run good oil.
Old 07-02-2011, 11:42 PM
Yep! Its easier to do as one job as you have everything stripped down to where it has to be anyway.
2011 National Enduro schedule gasgasman Off Road Racer's Corner 3 10-14-2010 09:43 AM
Valve maintenance 450 engine speeddemon Enduro Engine 4 stroke (including EFI & Exhaust) 5 02-17-2010 12:32 AM
2010 NEPG Schedule gasgasman Off Road Racer's Corner 4 10-30-2009 09:23 AM
AMA National Enduro '09 schedule gasgasman Off Road Racer's Corner 11 02-03-2009 11:06 AM
2007 WEC Schedule Berkyboy General Discussions & Announcements 0 08-18-2006 10:24 AM
