Old 01-10-2015, 04:45 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
Default Radiator hose prob?
Hello,
Have had this happen twice now on the 12.
The bottom hose that connects to the thermostat comes undone and pops off.
After the first time I changed the clamp to a proper hose clamp instead of the factory push clip things.
It happened again tonight and it looks as if the bottom of the thermostat is reducing in circumference as you move away from the thermostat itself, therefore if the clip is not real tight and happens to move a little it will come off.
I was thinking about putting a joiner pipe in place of the thermostat, anyone done this?
Cheers Mark
Xr 250 ( first bike)
98 Rmx
2008 280 Raga replica
2012 Gas gas ec 300 E
Old 01-10-2015, 07:21 AM
Wimpy525 Wimpy525 is offline
I would get rid of the thermostat. I had a real bad experience on my 12 when the thermostat housing blew apart sending hot coolant out. I could share some pictures of my leg after words but probably too gruesome for this site!
Checkpoint off road sells a in line cooler that what I replaced my with. When I got my 13 the thermostat was the first thing to go.
Old 01-10-2015, 02:51 PM
wence's Avatar
Ok, maybe that is the way I will go then. Is it just a joiner or a special part?
Do you have a link by any chance.
Cheers Mark
98 Rmx
Old 01-10-2015, 03:21 PM
n_green n_green is offline
http://checkpointoff-road.com/store.html
Current:
2014 Gas Gas EC300R
_____________________________________________
Previous:
2011 Gas Gas EC300 ELC
2004 KTM 300 EXC
Old 01-10-2015, 03:22 PM
I'd just get a joiner and slap it in there Mark. If you source em out and they're cheap let me know. I'll probably grab one too.
Old 01-10-2015, 03:34 PM
wence's Avatar
Thanks Nath,
Jake , probably will look for a joiner. Will let you know.
By the way the forks are better and don't bottom anywhere near as much now.
Cheers Mark
98 Rmx
Old 01-10-2015, 07:26 PM
shang shang is offline
I got rid of the t-stat housing after my '13 burned down. I never tested it but I suspect a failed t-stat was part of the problem. I just did an in-line cooler, no problems since.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 01-10-2015, 08:32 PM
Take the thermostat out and stick the temp sensor for a nice shiny new Trail Tech. At least that's what I did
Sent from my iPad using Tapatalk
Radiator Hose Clamps - Lesson Learned StuJohnson Enduro Other... 22 04-28-2014 12:14 PM
Wanted - left side radiator hose StuJohnson "Wanted to Buy" & "Want To Trade" 3 02-05-2014 05:53 PM
2011 300 blew off radiator hose Bark3rd Enduro Engine - 2 stroke 9 01-29-2014 11:47 PM
have radiator hose's changed ? motorhead Enduro Engine - 2 stroke 3 05-08-2011 12:00 PM
Question about radiator vent hose moto9 Enduro Engine - 2 stroke 3 05-22-2009 05:27 PM
