Old 10-23-2012, 09:34 PM
rocky2by rocky2by is offline
Default Head squish ?
Hello, I'm getting ready to send my 2013 EC300 head, off to RB Designs for his squish-band adjustment. Just wondered if there is anything I need to know about taking the head off and putting it back on, also draining the coolent, torque for the head bolts?
Thanks for any information,
Steve.
Old 10-23-2012, 10:56 PM
twowheels's Avatar
It's easiest done with the tank out of the frame, but you can do it by simply pulling the shrouds for access. Drain the water at the pump and if you're careful when you remove the water junction on the head you won't need a new gasket (IIRC the fiche has had the wrong part number for that little guy for years) and you can leave the hoses attached.
Having large enough diameter solder is important. RB spells out what type to get, but you may need to twist some together if the existing squish is larger than the diameter solder you're using. Take two or three samples. Snug is OK on the head bolts during the measurement process since you're not compressing a gasket.
This is a really decent mod for the money and I think you'll be happy you did it. Good luck and post back with any questions.
Steven Beane #275
afterhourscycle.com
Old 10-24-2012, 12:57 PM
andoman's Avatar
andoman andoman is offline
If you end up needing a new gasket for the water tee, call Gofasters and they will ensure you are getting the correct one. The fich calls it a "thermostat" gasket. Its obviously is not part of the thermostat.
I don't think anyone anywhere has been unhappy with a quality squishband mod. You will like the improvement. Especially the way it adds consistency in your search for jetting nirvana. Its worth twice the price for that alone.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 10-24-2012, 11:22 PM
twowheels's Avatar
Originally Posted by andoman View Post
if you end up needing a new gasket for the water tee, call afterhourscycle.com and they will ensure you are getting the correct one. The fich calls it a "thermostat" gasket. Its obviously is not part of the thermostat.
..... Fify
Steven Beane #275
afterhourscycle.com
Old 10-25-2012, 12:14 PM
Talking
Thanks for the information, I'll order some gaskets just in case I need them. I have about 5 hrs on the bike now and am really happy I went with the Gas Gas, its a super great bike.
Thanks, Steve.
Old 10-26-2012, 02:17 AM
andoman's Avatar
Ha! Well played, twowheels!
No slight intended when I mentioned the competition a few states over. I was just stating my specific experience. What I should have said is to call your parts source directly to make sure you get the right gasket in this specific case.
Old 02-24-2014, 09:54 PM
Default Help
Well I just now got around to have RB Designs do my head and carb work, and have all the gaskets here. What is the best way to get the two cyclinder-head O-rings to stay in place so I can get the head back on any information would be GREAT.
Thanks.
Old 02-24-2014, 10:00 PM
Thanks.
I use 3M spray adhesive.
You have to "pre-stretch" the o-rings to make them fit the cylinder.
Old 02-24-2014, 10:37 PM
A bit of grease can help, but they are a stupid size & stretching them carefully 1/2 doz times is the only option.
Old 02-24-2014, 11:39 PM
Thanks so much for the quick replies, I'll give the stretching option a go
Thanks.
Squish help. Ud_luz Enduro Engine - 2 stroke 39 02-14-2014 11:02 PM
Head Mod (squish) Madhead Enduro Engine - 2 stroke 17 01-16-2012 09:25 AM
Head squish machining in Oz oldktmdude Australia & New Zealand 2 06-28-2010 10:21 PM
Head Squish Article Questions FFRDave Enduro Engine - 2 stroke 17 08-19-2006 08:25 PM
Tech Article : Cylinder Head Squish webmaster General Discussions & Announcements 1 08-06-2006 08:45 AM
