Old 10-27-2008, 04:55 PM
Larsa's Avatar
Larsa Larsa is offline
Question Front brake is on all the time
The brake pads don’t let go when I spin the front wheel.
When I spin the wheel it stops after one lap.
I have tested all I can think of. It is not too much brake fluid.
I can also see that the front disk is not sitting 100% in the centre.
I have similar problems on the rear brake but not as much.
EC 300 -07
Cur GasGas GP 300-18, Prev GasGas EC 300 Racing-13, GasGas EC 300-10, GasGas EC 300-07 GasGas EC 300-05, GasGas EC 250-02,Suzuki RM250-98,Suzuki RM250-88, Honda CR250-86, Yamaha YZ400-79, Beta CR125-81, SWM 50-77, Italjet 50-76 www.dufvenberg.com
/Larsa
Old 10-27-2008, 05:32 PM
blitz11's Avatar
blitz11 blitz11 is offline
Does it stop in the same location every time? Bent rotor(s)? have you put a dial indicator on the rotor? Did you measure runout?
If you pull the caliper off, can you depress the brake piston? Is it stuck?
The master cylinder acts to both push the piston out (positive pressure) and withdraw the piston (negative pressure/vacuum). (That's why you have the return spring). If the piston doesn't move freely, the negative pressure will be insufficient to draw the piston back a bit.
Old 10-27-2008, 07:17 PM
Rick's Avatar
Rick Rick is offline
You might want to try bleeding the brakes. You can also remove the pads and check to make sure the front wheel make more than one lap. Check to see if the rotor is damaged. If not, you better look at wheel bearning/spacers/seals and that the axle is installed properly and torqued.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 10-28-2008, 06:37 PM
Larsa's Avatar
Default Still don't find the problem
I can press on the brake with my hands so that the brake cylinder depress.
When the brake and the wheel are installed on the bike. Then the wheel spinns perfect. After that I pump the brake handle and brake the front wheel.
Then the brake is on again and the wheel on spinns one lap.
I have clean every thing and oil the brake cylinder and the pad pinn.
And there are no mark on the pad pinn.
/Larsa
Old 10-28-2008, 07:59 PM
Larsa. How's it going?
You may have a restriction in the front brake hose. Sometimes a rock may hit the hose and cause internal damage that you can't see.
The internal teflon liner may have a section broken off that acts like a one way valve.
Try this:
Apply the brake until it acts up.
Loosen the brake hose at the caliper. If the problem goes away, then the hose is restricted.
If the brake is still locked up, then the caliper is sticking.
Old 10-28-2008, 08:02 PM
Larsa.
By the way, Mark Tracy is getting a 2009 Husaberg 450.
Old 10-29-2008, 04:37 PM
Larsa's Avatar
Default Now it works
Girard
I did like your advisory and when I loosen the hose brake bolt.
And the brake was still on. Then I swap the caliper from my son Yamaha YZ 125 than got the same Nissin caliper as GasGas. On the GasGas caliper support then I got it to work so something must be wrong inside the caliper. But I will fix this later for this week end I am going to race in the biggest enduro race in the world “Gotland Grand National” 2300 at the starting line for 3 hours http://www.gotlandgrandnational.com/
http://www.gotlandgrandnational.com/...ules_2008.html
Many thanks Girard you are great as always
I know that Mark has order a Husaberg -2009 450 and I think that bike looks cool.
I did not like the old Husberg it look very old but the -09 is a winner.
Do you know if Mark has got the Husa yet.
/Larsa
Old 11-11-2008, 03:13 PM
Larsa's Avatar
Default I did not find any problems in the caliper
I took the caliper apart and clean it but I did not find anything wrong.
So now I have the YZ caliper on my GasGas working and the GasGas caliper on the YZ 125cc working.
/Larsa
front brake crossover kai69 Enduro Other... 5 09-04-2010 04:47 PM
Front brake line? nick790 Enduro Chassis & Body 0 05-27-2009 03:50 AM
Front Brake protection? Link General Discussions & Announcements 3 09-17-2007 07:35 AM
front brake howl ec300 2t Enduro Chassis & Body 4 02-12-2007 07:33 AM
Front Brake Lever cladoo Enduro Chassis & Body 4 02-07-2007 08:45 AM
