Old 07-08-2011, 11:29 PM
CACTUSREID CACTUSREID is offline
Default need ohlins shock spring in canada eh?
i ordered a 5.6 spring for the rear of my 11 ec 300 approx 1 month ago. apparently they are back ordered from ohlins at the moment. we are just coming into the time of year that i park the gasser and jump on my 525 exc dualsport,because of the heat and dusty riding conditions. does any one know where i can pick up a spring,as this is prime time to strip the linkage,lube and install the bigger spring at the same time. i'm in the interior of b.c if that helps. thks . cactusreid
jumping on the 525 tomorrow and dualsporting up to sunpeaks to catch the opening round of the canadian world enduro series! should be KOOL-IO!
Old 07-09-2011, 12:14 AM
Tlineman Tlineman is offline
Did you try Ian at Riders Edge in Vernon? He stocks a fair bit of stuff
Old 07-09-2011, 08:36 AM
E-TECH E-TECH is offline
I have a 5.6 with only a couple of rides in it. It was from GOFASTERS i think it is a CONNON RACECRAFT 75$ Let me know if you want it
Old 07-09-2011, 11:04 AM
I used a Sachs spring on my Ohlins many will interchange, however for some reason the 5.6 aftermarket spring was slightly larger and we made a step collar to keep the spring from rattling around and rubbing something it wasn't supposed to.
Old 07-09-2011, 11:48 AM
motogroove's Avatar
I just stumbled upon this. Not sure how bad shipping and duties might be.
CLOSE OUT EIBACH SHOCK SPRINGS
Fits Models Spring Rate Final Sale Price
Most Ohlins and White Power 5.2kg/291.2Lb $45.00
Most Ohlins and White Power 5.6kg/313.6Lb $45.00
Most Ohlins and White Power 5.8kg/324.8Lb $45.00
http://www.kevinscycleracing.com/
look under closeouts, down near the bottom
Thanks to FLY Racing.
Old 07-09-2011, 12:01 PM
thks guys, E-tech,where are you located? I'm in kamloops bc canada. it may or may not make sense shipping wise.
Lanky Doug,that's the same thing that happened to me! the 5.6 that my local shop got for me was to big internal diameter as well.he has reordered based on the # on the current spring in my 2011 ec300 which is a 5.2 if i recall. i need a spring with a ID of approx 57.23 mm. the 5.6 that was to big was somewhere about 62 mm Id.
Old 07-09-2011, 12:21 PM
I got mine from Halls and thought it was packaged wrong. They measured other sized springs and only the 5.6 was that way. Les at LTR made me a spacer washer for free while he was re-valving my suspension so it all worked out. Maybe you could buy a spacer from LTR.
Old 07-10-2011, 08:01 AM
I live near Roanoke VA. Not sure about shipping to Canada. I guess FedEx or UPS does it?
Old 07-10-2011, 09:32 AM
ScottyR ScottyR is offline
Junior Member
I have been told that the TTX and the 888 Ohlins use a different spring.
From my experience, the Cannon springs are good quality but often test a little lighter than what they are supposed to be. I would suggest getting a 5.8 if you get one from Cannon.
Stock Spring Rate in '11 Ohlins Shock? bputt Enduro Suspension 2 01-13-2011 01:47 PM
Spring rate on Ohlins shock KicksonR66 Enduro Suspension 11 12-21-2007 02:58 PM
