Old 02-24-2024, 01:12 PM
Noobi06 Noobi06 is offline
Default Thermostat?!
I have two GasGas EC 125s. One of them has the stock Trailtech display, with a water sensor which I have attached a photo off. I am wondering if this is a thermostat that opens and closes, or if is just a tube with a sensor.
I found a thermometer on aliexpress for my other gasgas, but that is not a thermostat. Meaning if my other one has a thermostat, my second one without it will basically never get to operating temperature.
What is your input?
Old 02-24-2024, 07:04 PM
cbutler's Avatar
cbutler cbutler is offline
Both of them are just for temp readings nothing to open and close.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 02-25-2024, 01:27 AM
Small radiators on a dirtbike for packaging reasons. Just don't nail it from cold directly onto a motorway at 100kmph from cold and you will be OK.
Old 02-25-2024, 08:51 AM
Thanks for the answers guys! Will definitely buy one in that case.
On another note, what is the ideal operating temperature? Because my other gasser with the stock thermometer almost never goes over 40 degrees celcius. I mean it is kind of cold
Old 02-25-2024, 01:41 PM
Most riders (ktm included) remove the thermostat - one more thing to go wrong and end a race. They often just add a temp switch and fan. Normal operating temp is between 90-110 deg C i think (i had one of those temp stickers on my radiator so not accurate) but depends on your radiator cap. the 1.2bar cap will boil over at 104 C and 1.4 bar at 109C but coolant is higher.
If your bike is running at 40C that is low and you must be riding very easy stuff or very cold weather in which case it may be better to add a thermostat. My experience has all been at the other end of the spectrum with preventing a bike from boiling over in the rocks
Old 02-25-2024, 06:20 PM
Ideally a modern (if there is such a thing anymore) 2 stroke roadrace bike would run at a detonation killing 50*C .
Obviously this isn't the case here but I'd not want to go below that , but i think your gauge is probably fibbing to you.
We used to say 70*C in the old days of steel liners. But dirt bikes have tiny radiators so some of that is aspirational.
That said light load on the road when not hanging it but at a nice speed and only a 125cc engine to heat the water, you might be a lot cooler than a 250 stuck in deep mud at 6kmph with an impatient tired rider.
Old 02-25-2024, 06:40 PM
farmerj's Avatar
farmerj farmerj is offline
If your bike is running too cold - a lot of folks will cover one (not both) of the radiators with a piece of cardboard or plastic. Lots of times you can slide this between the radiator and a guard.
Easily removable, and cheap way to solve a problem!
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 02-26-2024, 02:24 PM
Wow okey. I do not really know what to do to be honest.
I have the OEM GasGas thermometer connected to the vapor trailtech.
It reads from the water and says 40C, or lower.
I do not really know what to do. There are 2 plastic covers that you have on almost all bikes, though I have not put them on but I doubt it would make a difference.
I run it at idle for 5 minutes+ and I always start slow but it never goes to operating temperature.
Note that I am running roads, laying at 60kmh with around 15-25 degrees celcius weather.
What should I do?
Old 02-26-2024, 04:06 PM
SS109 SS109 is offline
Seems off to be running that cool. However, I would do like farmerj suggest and block one radiator, run it, and see where you end up temp wise.
Old 02-26-2024, 06:11 PM
I appreciate the answers guys! Will definitely try some things when the snow is gone, like blocking a radiator
Do I need the thermostat? Tripp Enduro Engine - 2 stroke 1 08-21-2023 01:22 PM
Check your Thermostat! farmerj Enduro Engine - 2 stroke 1 10-18-2021 07:46 AM
Radiator thermostat. masterbill Enduro Engine - 2 stroke 6 04-16-2019 10:48 AM
2011 thermostat setpoints Berkyboy General Discussions & Announcements 19 08-10-2018 02:17 PM
