Old 03-12-2012, 01:29 PM
bonkeye bonkeye is offline
Default breather tube
started the bike today as i havent been out on it for about a month, ive notice there's some white smoke coming out of a breather tube from the head think its the power valve breather tube? did have one or 2 drops of fluid come out but it stopped when it was up to temp..... also latlry the bike has taken quite a fair few kicks to get it going.... new plug & filter is clean
any idea?
Old 03-12-2012, 06:59 PM
any idea?
A bit of spooge from the breather hose is normal. Smoke would be it burning off. If you have ever run the bike with the PV cover off you'll notice a bit too.
Does the bike always take a while to start or only when cold? I've had bikes in the past that were absolute pigs to start if left for more than a week unstarted.
Old 03-12-2012, 08:59 PM
the bike used to start first kick from cold without fail, just slowly getting worse now.... also if i come off or bike is put on its side its a real pain to start hot or cold
Old 03-12-2012, 10:05 PM
Have a look in the exhaust port and see if theres much blow by on the rings. When was the last time it had a top end?
Old 03-13-2012, 12:30 PM
i fitted new exhaust sealing rings about a month ago so no sign of it blowing as fir the top end idea.... ive had it nearly a year & hasnt been done since ive owned it, i'll see if i can borrow a compression tester from somewhere, what presure should it be roughly? should have said earlier but its a 2000 model 300 EC
Old 03-13-2012, 06:09 PM
I'd be aiming around 165-175psi for a stock engine.
new GG member with some GG questions powervalve breather and overflow bottle swazi_matt Enduro Engine - 2 stroke 8 02-04-2011 10:24 AM
white gunk coming from crankcase breather tube Crankin04 Enduro Engine 4 stroke (including EFI & Exhaust) 22 07-18-2010 09:58 AM
Oil leak from breather pipe TXT pro 250 jamesukm General Discussions & Announcements 0 04-22-2010 12:59 AM
pv breather jprh Enduro Engine - 2 stroke 5 02-21-2009 08:38 PM
Take out spark arrester for FMF PCII? PV breather + Silencer lengths gasser250sm Enduro Engine - 2 stroke 0 02-20-2009 02:00 PM
