Old 08-25-2008, 08:12 PM
Sharpie Sharpie is offline
Default 50 boy
My son has a 2000 50 boy when it is cold it starts on the first kick. It runs fine for 10 min's and then stalls and won't restart until it is fully cooled off it never gets to hot just a normal warm temp. What could be wrong?
Old 09-09-2008, 01:13 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Your problem may be heat related, but I think you ought to check for something else before you start on that path.
What you describe is often caused by a vacuum building up in the fuel tank, which starves the engine for fuel.
After the engine is off for a short while, the vacuum will bleed away and the fuel will once more flow enough for the engine to run for a short while. The fuel leaving the tank will cause another vacuum, which starves the engine again.
Check to make sure that the gas cap is venting.
Good Riding and Wrenching,
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 09-14-2008, 01:29 PM
Steve@Motowest Steve@Motowest is offline
Have you checked for spark when it's not starting? The stator may be failing when hot, a common occurrence.
