Old 08-16-2009, 04:10 AM
Skele Skele is offline
Question Cylinder to Crankcase Gasket order?
I am currently reassembling the top end of my '03 EC200 and i realized that there are THREE different gaskets that all sit on top of each other between the cylinder and the crank case. I have no idea of the order.
See page 113 and 114 of the link below to see what i am referring to (also shows thicknesses)
http://www.gasgas.com/manuals/ec_parts_03.pdf
Does anyone know the correct order?
Old 08-16-2009, 04:40 AM
Brian VT Brian VT is offline
The order doesn't matter.
Also, many of us have gone to a single gasket. I use a single 0.3
Some even use a single 0.15, although I've read it doesn't always seal well.
I think stock is usually 0.3 + 0.5, not all three, but I guess no harm in using them all.
Some other threads:
http://www.gasgasrider.org/forum/sho...ht=base+gasket
Crankcase vent blocked kendunn Enduro Engine - 2 stroke 2 10-06-2009 12:37 PM
Swingarm installation order? Trailrider Enduro Chassis & Body 2 06-18-2009 11:08 AM
Cylinder gasket leaking. GavGav Enduro Engine 4 stroke (including EFI & Exhaust) 2 05-18-2009 01:25 PM
What parts should I order for Marzoc 45mm? brains Enduro Suspension 2 05-05-2009 08:34 AM
Where order shims borsiin Enduro Suspension 5 12-10-2008 04:45 AM
