Old 06-28-2008, 03:34 PM
mountain thumper's Avatar
mountain thumper mountain thumper is offline
Default cheapy dc?
i want to run full lights on my 07 ec300, i have to 2k2 stator, which i already have overworked with my headlight/tail/brake.
(see 07 speedo post) can i just put in a rectifier /cap to run the horn, guages and signal flasher?
im not sure i even understand a rectifier. trailtechs website says dc stator not included, but i thought a rectifier was to convert ac to dc. i already have a street plate(dmv didnt even hesitate) but if i get pulled over, im boned for lack of other required street goodies.
and how much energy can a capacitor store, i mean (not an electrician by any means) it doesnt change the output , just saves it for high demand situations id imagine, ie horn or signals on top of ignition and enduro lights..
i appreciate any help
Le Crutan
98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD)
FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck:
Old 06-29-2008, 11:34 AM
slocalspode's Avatar
Read this series of posts.
http://www.gasgasrider.org/forum/sho...ght=converting
this should give you something to chew on.
It seems there are two, (or more), ways to go about it. Depending on
how much power consumption you plan on needing.
I believe the TrailTech, and other full wave rectifiers, need to have a
floating ground to function properly. There are other type of rectifiers
that do not. I assume most normal street bike applications do not
use a floating ground system.
I need to dig out my pictures and make a post on my stator upgrade
and floating ground modification. It's not THAT hard once you learn
what is needed and how to do it.
Good luck. Jeff. So.Cal.
Old 06-29-2008, 04:11 PM
well, ill be running a (trailtech) endurance probably, with flushmount led blinkers, i have a 35 watt headlight and a 15 watt taillight as is, and my stator is rated at 40 i think..
ive read the post about floating the ground and modifying the stator, but i dont want to risk farking up my brand new toy, yet anyway. im not even sure if i need dc, but i havent seen any flasher units that operate on ac, and either way, ill need a little more reserve power.
Le Crutan
Old 07-01-2008, 09:31 AM
I believe the stock EC (2-stroke) flasher is for an AC system. After I did my
floating ground mod and installed the battery. My stock flasher did not work.
I replaced it with one from the local auto store. I had to swap around the
three wires in the connector to get them in the right orientation for the
auto flasher to work properly though. I think most of the GG electronics
are made by Leonelli. They have a web site with descriptions of how their
stuff works.
Depending on what you want to do with your GasGas. You may not need,
or want to go DC. All your lights and, with the right one, horn will work off
AC. As far as I know, only a cooling fan, and LED lights need to be DC.
My stock EC horn had a small rectifier mounted next to it in the head
light shell. It should be powerful enough to power LED's, a fan or a speedo.
Good hunting. Jeff So. Cal.
Old 07-01-2008, 11:28 AM
For Mountain_Thumper:
Here is the linkie for the Leonelli information.
Look at pages 20-21 for the flashers, horns and
Rectifiers / Regulators.
http://www.leonelli.com/english/general_catalog_05.pdf
I think the GasGas Rectifier is Ref: 080.B. You may need the
voltage regulator Ref.: 090.A to with it.
The AC flasher is Art. 355 Mod B. and there is two
versions of the AC horn and one of the DC type.
Hope this helps. You GG dealer should be able to order
these for you.
Jeff, So.Cal.
Old 07-01-2008, 09:46 PM
i honestly dont like going to my local dealer, his labor is too high, and parts are outrageous. he told me it would cost me 200 to enduro lite my ec. it cost me less than 50 to do it myself.
the link you gave me isnt quite right either, u know it says english, buts its in spanish. im gonna switch out english for spanish and see if they switched em.
Le Crutan
Old 07-02-2008, 09:01 AM
Son of a Gun. You're right I wonder how that happened??!?!?
I did a "copy/Paste" from the .pdf file I was reading. And it was
in English......strange.....
Try surfing the web site. It should be easy to find the English version.
GG dealers are great for "on-line" sales. You do not need
to support your local thief if he/she won't treat you right.
Best wishes.
Jeff
Old 07-04-2008, 07:09 AM
cdn280 cdn280 is offline
I wouldn't bother with the Leonelli flasher. Mine died shortly after getting the bike and I replaced it with a $3 2prong auto flasher and has worked for 2yrs now. Apparently its used on a lot of 2T scooters (AC) as well and its a lot more than what I paid for a replacement.
I took the Leonelli piece apart to see what was wrong and it was full of water. Basically a plastic case with a cardboard bottom. I don't think the new one is water tight either but I ziptied it in an upright position so it would drain.
Old 07-07-2008, 11:58 AM
You still need a certain amount of power and if you add up the loads the 35W 2K-2 is not going to make it. My wife's 250 Pampera has the AC/ halfwave DC system with the Leonelli rectifier for the fan, horn, and flashers, but it also has a much larger ignition.
Old 07-07-2008, 04:50 PM
I would tend to agree with Glenn. The man knows his stuff.
My 2002 XC300 with the 2K2 stator running in AC mode
had enough power to run the stock headlight, tail light and
honk the horn as well as use the turn lights. As long as you
did not try using them all at once. For a real street legal
bike. It could be lacking as well as possibly dangerous.
You don't want to be suddenly without lights on the highway
or stopped at some busy intersection in town.
And that is why I converted my XC into an EC with the 2K3
stator, floated the ground. Installed the trailtech rectifier
and a sealed 1.2Ah lead acid battery in the air box.
Now, if I am going down a long steep rocky trail in the dead
of night and stab a little too much rear brake & kill the motor.
It won't leave me in pitch blackness wondering where the
trail went.
Or like the time I forgot to turn on the gas petcock. Took off
for home and had the motor starve for fuel leaving me stranded
in the middle of a 6 lane street during rush hour here in Los Angeles.
Keep an eye out for a used 2K3 stator or maybe offer a trade for
your 2K2. Someone here on the list might want to swap with you.
Cheers, Jeff
