Old 10-14-2015, 12:33 AM
Default Beta X-Trainer
So this weekend we had a bunch of old bullets (some almost 70) down here for a riding weekend and in the mix was a beta dealer who brought a '16 Xtrainer and I could not turn down the opportunity to test it.
To give some background to what I ride it is a 2010 ec300 with SP/twowheels tuned kyb sss forks, Scott's damper (because I already had it) and racetech Sachs shock, PV spacer, NEDJ needle and tubliss all round - so it is set up nice and no reason to Change anything
The beta I believe was stock (dealers first ride)
Sitting on it,it felt similar to the GG although a bit lower at the back (poss too much sag) clutch pull is a bit harder than the ajp and no kick start
Riding it feels smaller/lighter than the GG like a heavy trials bike with a seat. The power is on par with the GG but much smoother (very linear), doesn't pull your arms when you accelerate and it has good legs (it will apparently keep up with a KTM 300 on a drag strip and I believe it - you can just keep twisting the throttle ). I rode it on some tight rocky single track paths and some more open jeep tracks and honestly i wouldn't have been any faster on my bike I also felt that the bike could still go faster (and I could go much longer without getting tired on the beta because of the smooth power)
The suspension was faultless with the only downside being the front end felt a bit loose/twitchy this could be because of my bike having a damper or the suspected too much sag - not scary twitchy though more light. And with the light weight of the bike it is slightly easier to throw around and the front end comes up much faster than I am used to. The forks felt fine with no diving or deflection
Bottom line I could switch to this bike in a heartbeat and feel comfortable on it (I usually take a while to adapt to different bikes) this is testament to how similar it is to my bike. A really nice bike a pity I could not ride the 300rr to compare that as well. But for the technical riding I do I could happily buy this bike
Old 10-15-2015, 12:17 PM
thumperflipper thumperflipper is offline
Thanks for that great review! I've been thinking of that bike a lot, but I have my gasser right where I want it now. But as a smaller rider, the XTrainer is always in the back of my mind....One of the west coast mag reviews thought the suspension was too easy to blow through...did you find that as well? Did you jump it? And what is your rider weight?
07 GG EC300
11 GG EC300E
Old 10-15-2015, 03:22 PM
paulos paulos is offline
I like the concept of the bike, but....no kickstart = no way would i buy one
2011 Gasgas EC200, 1966 BSA 350 scrambles, 1972 Montesa cota 247
Old 10-16-2015, 01:26 AM
Anders Anders is offline
If that is your biggest concern when buying a bike, your options will soon be limited I'm afraid.
I have never seen a Xtrainer in the flesh, but I presume it's the same engine cases as the other Beta twostrokes? I that case, I presume a kickstart could be retrofitted (with more or less hassle).
Old 10-16-2015, 06:55 AM
Yeah i know. I don't know why manufacturers are going down this path? I would much rather have a bike with a kickstarter and no electric start than the other way around.
Old 10-16-2015, 10:22 AM
twowheels's Avatar
There is a kit to allow fitment of the kickstarter. On some machines (think Sherco) the cases don't allow this, nor would the frame as there is no relief where the kickstart knuckle would need to swing.
Steven Beane #275
afterhourscycle.com
Old 10-16-2015, 06:15 PM
I presume, and others have ventured to guess, that the e-start only on the Sherco is in preparation for fuel injection on their 2t bikes (rumors of this for 2017). Apparently their injection design does not work well with a kick starter and would be essentially useless.
Old 10-16-2015, 08:12 PM
arminhammer arminhammer is offline
Or the factory could add a 2oz capacitor and keep a kick starter for back up.
Old 10-16-2015, 10:19 PM
JP4's Avatar
JP4 JP4 is offline
If an engine is designed without consideration for a kickstarter, why would it not follow that the frame on the corresponding motorcycle wouldn't allow for the installation of a kickstarter?
Am I missing something? Is there a point otherwise?
Old 10-17-2015, 12:10 AM
twowheels's Avatar
The first KTM 4Ts that came without a kicker still had the sweep in the right hand frame downtube to allow for one.
In a symmetric world the left and right downtubes would mirror each other but they often don't for packaging reasons.
Steven Beane #275
afterhourscycle.com
New 2015 Beta 300 X Trainer Moto7man All Other Bikes... 15 02-27-2015 01:04 PM
Gasgas Vs Beta nato All Other Bikes... 25 01-29-2014 07:00 PM
Might have to buy a Beta!! schlitzy Pictures & Videos 9 11-27-2013 10:37 AM
Beta 250 ?? mikesixdays All Other Bikes... 7 08-16-2013 08:53 PM
Pfeiffer to Beta ? :>( cdn280 General Discussions & Announcements 0 07-16-2007 06:50 AM
