Old 09-13-2008, 09:08 PM
Default Changing fork springs
Can this be done with the front end left on the bike??
IIRC .... I'm thinking the tricky part would be keeping the little rod from sliding down into the fork tube while trying to swap out the springs. If the rod responds to a magnet you could get it back up with a magnet extender but I'm thinking its aluminium....
Old 09-13-2008, 09:45 PM
cladoo's Avatar
cladoo cladoo is offline
That's how I did mine. I think the rod is steel.
Claude
2019 XC300
2010 Nambotin 300 sold
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
'75 Yamaha YZ250B sold
Old 09-14-2008, 02:55 AM
bergerhag's Avatar
Put the bike on a stand, unscrew your fork caps, then lift up the front wheel and put another stand under the wheel. This way you can work on the spring change with the fork fully compressed and there will be no need to fish out the inner rod..
Old 09-14-2008, 10:42 AM
sweeet!!
I wouldn't have thought of that!!
Old 09-20-2008, 08:59 PM
Damn that was easy!!
Thanks for the tip B hag ...
spring change out was boob!!
any tips for changing out the rear ohlins??
Old 09-21-2008, 03:00 PM
To pull the rear shock.
Remove the exhaust pipe and unbolt shock.
Pull out on the right side of bike.
You will have to move the swing arm up and down as you pull the shock.
I saw Billy Burns do this in about 2 min.
Old 09-21-2008, 07:41 PM
Thumbs up
Yes, thats the slick way to do it. On the '03+ bikes its easy as the top shock bolt is lower and eaisly accessable. Never tried it on an older GG but I think the tank will have to come off too to access the bolt. Still better than pulling/pivoting the subframe.
Old 09-21-2008, 09:48 PM
I was thinking more in the way of changing out the spring on the rear ohlins ... some shocks you can loosen the spring, remove a ring on the bottom spring mount and drop the spring down. other shocks aren't so easy and require a spring compression tool.
btw .. i rode with the 42's up front today .... jury is still out but .... seemed alot nicer. I also backed rear preload from 10 mm back to 8mm. I added two clicks to compression and two clicks for some more rebound damping to the forks. seemed like I had a bit of front end wallowing/head shake on some down strokes. was riding tight technical stuff that was a little slick in places .. maybe it was my mt 19 sliding around...
Old 09-22-2008, 05:49 AM
Brian VT Brian VT is offline
You don't need to compress the rear spring.
Old 09-24-2008, 03:17 AM
iancp5's Avatar
iancp5 iancp5 is offline
Damn I took 2 hours! Must try it this was next time instead of removing all the linkage and back wheel, loosening the subframe to swing up .....................
Where to buy fork springs for WP dank Enduro Suspension 4 05-07-2010 05:28 PM
Fork Springs Looki General Discussions & Announcements 4 04-10-2010 06:52 AM
Fork springs - 0.46 stay_upright Enduro Suspension 4 03-26-2009 11:16 PM
Changing fork oil in Zokes? ktmguy23 Enduro Suspension 2 03-21-2007 11:53 PM
