Squeaky clutch at high temps and strange drag ?
At very high temps, the clutch starts to squeak witch doesn't bother me too much. The problem is it also sticks too fast when i try to slip it, witch results in a very jerky feel witch doesn't feel normal at all. This happens only when the bike is very hot after (or in) a difficult section like a very muddy and slippery situation witch may take me 4-5 tries to overtake.
Question: Should i take the plates off to inspect/change them or is this normal ?
'14 EC300 |
Sounds like warped steel disks to me.
They are on sale at 24 euros + 64 for the disks original, or should I go with aftermarket like Aoki or Barnett ?
'14 EC300 |
In my experience the OEM disks are ok.
But I would take them out and check them before doing anything else Sent fra min GT-I9295 via Tapatalk
Is this a new thing?
My 14's clutch was victim to the same issues until I drilled more holes in the inner clutch hub, now it takes all the abuse I can give it!
2021 Beta 300RR 2014 Gasgas XC300R 2019 850 Pro RMK |
Thanks.
'14 EC300 |
Squeaks are quite common. Its the drag I'm referring to when I suggest warped disks.
Yes, that's why i'm asking. I do not mind the sound but the sudden drag when slipping the clutch when the bike is very hot.
'14 EC300 |
How many holes and witch size?
might worth checking also the radiator fluid and transmission oil after that use (boiling)
EC250 2019 |
Yes my Clutch does drag. | (F5) | Enduro Engine - 2 stroke | 42 | 04-09-2019 12:11 AM |
Clutch drag is doing my head in !!!! | Packman | Enduro Engine - 2 stroke | 9 | 06-30-2013 03:59 AM |
Clutch drag.... | BluegassXCR | Enduro Engine - 2 stroke | 3 | 07-04-2011 03:27 PM |
Does your clutch drag? | stay_upright | Enduro Engine - 2 stroke | 11 | 06-05-2008 03:14 AM |
Clutch Drag? | Gas Huffer | Enduro Engine - 2 stroke | 5 | 12-11-2007 05:02 AM |
