"Wanted to Buy" & "Want To Trade" Bikes or Parts |
Transmission gears and shift forks for 2000 xc250 wanted
Need transmission gears and shift fork rods for my 2000 xc250.
Got a used bike and the transmission is grenaded! Contact redronley@gmail.com. Thanks!! |
Ow.
Ive never seen that kind of damage on any bike transmission. Musta tried to ride it out of wherever the thing started coming apart at. |
I dont know what caused it to fail, PO did not disclose.
Needle bearings were everywhere. |
There is a gear set on Ebay from a 2009. I think it will work in the older bikes but would like another member to confirm.
http://www.ebay.com/itm/GAS-GAS-EC30...NXohMK&vxp=mtr You should also check with this member too. http://www.gasgasrider.org/forum/showthread.php?t=22228 |
Yeah, it looks like the 09 may work. I don't know yet why it failed, would hate to grenade another gear set!
Ill compare stack to BOM fiche to see if clip was missing. Needle bearing pins everywhere. Ill start a technical post in another sect. Need parts! |
I would check and/or replace the shift forks and shafts, and give the shift drum a close look as well.
Just bought a complete bottom end assembly from another member here.
Thanks for the advice! |
Tags |
trans transmission |
2009 450 transmission gears, forks, shafts | WASHINGTON STATE | Parts | 1 | 01-29-2017 02:47 PM |
Wanted! Trans Gears! 200/250/300... | shang | "Wanted to Buy" & "Want To Trade" | 6 | 03-15-2016 10:24 AM |
2000 Gas Gas XC250 roller | gasgasxc | Parts | 21 | 10-29-2015 03:37 PM |
2000 xc250 part out | 675AZ | Parts | 2 | 03-04-2013 09:18 PM |
2000 XC250 spring arm to shift cam assembly method | 70455 | Enduro Engine - 2 stroke | 0 | 12-18-2012 07:38 PM |
