Old 04-20-2020, 02:33 PM
Sadberry Sadberry is offline
Default 2019 ec300 crank bearing issue
Hey guys wondering if anyone has info for possible factory recall on crank bearings for 19 300. My bike has 97 hrs on it changed oil, never sunk it in water. After warm up yesterday it started making a noise in the crank case. I got home took stator cover off and the bolts that hold the starter gear on were loose with no loctite. I torqued them down and grabbed the staor it had a little play. I started it without the cover on and after about 45sec of warmup you could see and start hearing the crank move up and down as you would rev slightly. I only ran it to see if tightening those bolts would have been the issue. Any info helps thanks guys
Old 04-20-2020, 03:53 PM
blitz11's Avatar
blitz11 blitz11 is offline
Stator has play or the ROTOR has play? You wrote stator.
Old 04-20-2020, 08:21 PM
The whole stator moves with the crank.
Old 04-20-2020, 10:43 PM
Remove the ROTOR bolt and re torque and loctite. There has been cases of it being loose.
Old 04-20-2020, 11:37 PM
Aahh sorry yes the rotor. It makes horrible noise after almost a min of running. Ill try it.
Old 04-24-2020, 02:38 PM
any news?
Old 04-24-2020, 06:42 PM
I pulled the flywheel off and the crank bearing is deffinetly smoked ! Im ordering everything to rebuild and ill have it balanced up.
Water pump shaft issue. Bearing spun? gassybill Enduro Engine - 2 stroke 7 07-03-2017 03:45 AM
Crank bearing failure .WTF ? Getoviq95 Enduro Engine - 2 stroke 2 04-16-2017 01:27 AM
Crank bearing help please!!!!!!! Porkyblader Enduro Engine - 2 stroke 2 09-09-2011 04:46 PM
07 Crank bearing... NEED URGENT HELP. wence Enduro Engine - 2 stroke 11 05-23-2010 02:25 PM
03 EC300 crank bearing problem bwalker98 Enduro Engine - 2 stroke 4 05-04-2010 05:05 PM
